Playing an ORBX from Unity in ORBX Media Player
Forums: Playing an ORBX from Unity in ORBX Media Player
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
Re: Playing an ORBX from Unity in ORBX Media Player
Postby Goldorak » Tue Jan 02, 2018 8:27 pm
Goldorak Tue Jan 02, 2018 8:27 pm
dev19872014 wrote:Hi,
How to play Orbx file from unity?
I tried all above solution but still not play.
All example have js extensions so if required then How to convert in js or please guide how to play in gear vr?
Thank you in advance.
ORBX media files for GVR (basically platform specific compressed ORBX package from render job node/script) are largely cloud (ORC/RNDR) only (currently it takes longer to compress an 18K cube map than to render the same frame on average scenes!). We will move the packaging of ORBX media fully off cloud and into Unity Editor, sometime after MPEG-I/HNSS format gets close to final form in the coming months - which will likely share the root container and much of what is in XML schema as ORBX. In the meantime, nothing in the free version of Octane/Unity prevents you from dropping your rendered JPG, EXR or PNG files into a folder for testing playback in OMP. You could even zip the folder (though I don't recommend the latter due to speed hit and limitations of ZIP format).
Goldorak
Postby wxyz » Sun Apr 01, 2018 5:04 pm
wxyz Sun Apr 01, 2018 5:04 pm
Is it now possible to render VR from Unity w/o ORC?
wxyz
Postby wxyz » Sun Apr 01, 2018 6:57 pm
wxyz Sun Apr 01, 2018 6:57 pm
Rendered out a sequence of png's at 18432, how do I create the orbx file?
wxyz
Postby Goldorak » Mon Apr 02, 2018 8:34 pm
Goldorak Mon Apr 02, 2018 8:34 pm
wxyz wrote:Rendered out a sequence of png's at 18432, how do I create the orbx file?
If it is just to test a small set of frames, you can drop it in a folder and try it in OMP. The compression to OKX format is only on ORC for the moment.
Goldorak
Previous
Return to Octane for Unity
Who is online
Users browsing this forum: No registered users and 10 guests
Fri Apr 19, 2024 2:21 pm [ UTC ]
