[20.6] When adjusting nodes, viewport does not render
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
grimm
When in the "Shading" workspace and I am adjusting shader node values, the viewport will not start to render. It will go through updating the shaders, render, and then it gets stuck on "Waiting for image...". I have waited for several minutes to see if it will start to render, but doesn't. It will only start if I rotate the view a little, then it renders normally.
It will also start to render normally if I connect or disconnect a node.
Jason
DrawFun
Hello, grimm,
Thanks for your report.
Generally, it is caused by some invalid updates in the node graph - octane rejects the update so no changes happen in that case.
We've noticed this problem and will try to solve it in the future versions.
DrawFun
Return to “Bug Reports”
