OctaneRender™ for Blender 2020.2 - 23.1 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Upgraded to 2020.2
  • Added "Priority" attribute in materials
FIXES SINCE LAST RELEASE
  • Fixed group node render issue
  • Fixed Eevee/Cycles render crash
You can read about new features of OctaneRender™ 2020.2 here:
viewtopic.php?f=24&t=76901
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows or 455.23 on Linux to use this version. No driver updates are required for macOS 10.13 (CUDA).
1. OctaneRender™ Server
Windows
Blender Octane Edition - 23.1 (2.91.2)
Octane Server - Enterprise Edition - 23.1
Linux
Installation:
$ OctaneServer &
DOWNLOAD
macOS (CUDA)
DOWNLOAD
