OctaneRender® for Maya® 3.05.3 - 9.22 [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2015, 2016, 2016.5 and 2017 64-bit on Linux operating systems, and 2016, 2016.5 and 2017 64-bit on OSX operating systems (including and above 10.9).
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of Octan eRender™ Standalone on your machine.
viewtopic.php?f=24&t=58640
  • Relaxed the requirement of unique transform names for Maya versions including and later than 2016.
  • Fixed the region rendering bug.
Windows
DOWNLOAD
OctaneRender for Maya 9.22
OctaneRender for Maya DEMO 9.22
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 9.22 Linux
OctaneRender for Maya DEMO - 9.22 Linux
OSX
Installation:
- Just run the autoinstaller file.
DOWNLOAD
OctaneRender for Maya - 9.22 OSX
OctaneRender for Maya DEMO - 9.22 OSX
p.jsi
Hi there,
The region render bug for maya still exists in terms of whenever you reopen render view you would have to check and uncheck 'pick focus region'. If its off shouldn't render region already work when you open render view the next time?
I am using the 3.06.4_11.7
