Texture enviroment
Forums: Texture enviroment
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Texture enviroment
Postby Ebo » Mon Oct 21, 2019 9:24 pm
Ebo Mon Oct 21, 2019 9:24 pm
Hi, unless there is something I am missing. When I want to stop using hdri in Texture enviroment slot, even after deleting the picture path. Hdri is still there and it is not possible to get total blackout. I hope I am clear enough. I am not the best English speaker :).
Ebo
Re: Texture enviroment
Postby juanjgon » Mon Oct 21, 2019 10:12 pm
juanjgon Mon Oct 21, 2019 10:12 pm
Yes, sorry, this is a known issue related to the fact that Octane doesn't reset the string parameters if the string is empty. The workaround is to write something, any string, in the parameter, for example "clear" ... this will delete the current texture path. Probably something could be done from the plugin side to avoid this issue. I'll think about it.
Computer Graphics Software Developer
Octane plugin development and support: LightWave and Houdini
juanjgon
Postby Ebo » Tue Oct 22, 2019 10:23 pm
Ebo Tue Oct 22, 2019 10:23 pm
ok, thank you
Ebo
Postby Ebo » Sat Oct 26, 2019 4:19 pm
Ebo Sat Oct 26, 2019 4:19 pm
I tried that clear thing you said and it did not work. Only thing that works is to create new RTarget.
Ebo
Return to Bug Reports
Who is online
Sat Jul 04, 2020 6:00 am [ UTC ]
