Instance color changes per frame
Forums: Instance color changes per frame
Houdini Integrated Plugin
Postby WoutTgh » Mon Mar 02, 2020 7:31 pm
WoutTgh Mon Mar 02, 2020 7:31 pm
I'm using the random color node as an input for a gradient to color instances but it changes with every frame. I tried explicitly creating the id attribute on the points ( [email protected][email protected]; ), and set to "Instances Id's from" to 'id' point attribute.
But it's still , well, a little bit too random :)
Wout
WoutTgh
Re: Instance color changes per frame
Postby WoutTgh » Mon Mar 02, 2020 7:58 pm
WoutTgh Mon Mar 02, 2020 7:58 pm
OKay, fixed:
I used the this osl shader:
#include <octane-oslintrin.h>
shader randomColorGreyFromInstance(
int seedI = 0 [[string label = "Seed"]],
output color c = 0)
float noiseOut = noise("cell", (float)(_getinstanceid() + seedI));
c = color(noiseOut, noiseOut, noiseOut);
and added the Id attribute as described above. Still, the random colour node might need an update to not be random over time ! :)
WoutTgh
Postby juanjgon » Mon Mar 02, 2020 9:13 pm
juanjgon Mon Mar 02, 2020 9:13 pm
This problem can come from the multi-thread scene extraction feature, or from the fact that Houdini is modifying the internal instances order in each frame. Can you please attach an example scene with this problem to take a look at it here?
Computer Graphics Software Developer
Octane plugin development and support: LightWave and Houdini
juanjgon
Return to Houdini
Who is online
Users browsing this forum: No registered users and 2 guests
Wed Jan 27, 2021 2:04 pm [ UTC ]
