Override obj materials, one way...
Forums: Override obj materials, one way...
Houdini Integrated Plugin
Postby Humpti » Fri May 10, 2019 12:15 am
Humpti Fri May 10, 2019 12:15 am
Hi, took me some investigation to find a way how to get rid of the nice magenta rendering ;)
I don't know if this is the only way or if I can delete any former materials directly, but I added a material node under the file import node and for the group I entered @shop_materialpath=="/mat/floor" as you can see in the spreadsheet primitives tab and as material I set a predefined Octane material.
Any other known/better way to handle this?
Humpti
Re: Override obj materials, one way...
Postby juanjgon » Fri May 10, 2019 5:46 pm
juanjgon Fri May 10, 2019 5:46 pm
You can set the materials at the OBJ level using the "Material" parameter, or if you are importing objects with groups or you want to set materials at the primitive level using the Material SOP. These are the two standard ways to set the materials in Houdini.
Computer Graphics Software Developer
Octane plugin development and support: LightWave and Houdini
juanjgon
Postby Humpti » Fri May 10, 2019 7:19 pm
Humpti Fri May 10, 2019 7:19 pm
Ah yes, cool, that should give me enough possibilities :)
Thanks!
Humpti
Return to Houdini
Who is online
Users browsing this forum: No registered users and 2 guests
Fri Feb 21, 2020 4:52 pm [ UTC ]
