by juanjgon » Tue May 15, 2018 5:47 pm
juanjgon
You have an extra " character in the PATH variable, just before the $PATH string. If you remove it, probably the plugin should work ... but, why are you installing the plugin in your $HOME folder? I'm not sure if this is a good idea (and in this case, probably you don't even need to add these variables to the houdini.env file, becasue the $HOME folder is already available by default for Houdini)
- Attachments
Computer Graphics Software Developer
Octane plugin development and support: LightWave and Houdini
