Octane_3.00.12.0 Crashes
Forums: Octane_3.00.12.0 Crashes
Houdini Integrated Plugin
Postby UglyStupidHonest » Fri May 13, 2016 9:58 am
UglyStupidHonest Fri May 13, 2016 9:58 am
I'm sure I made a mistake somewhere but I cant find it every time I open the IPR in 15.0.459 I get this message "Can't open the log file "$HIP/Desktop/octane.log"
. Its the first time I have this error.
UglyStupidHonest
Re: Octane_3.00.12.0 Crashes
Postby juanjgon » Fri May 13, 2016 10:06 am
juanjgon Fri May 13, 2016 10:06 am
The log options are in the plugin options panel. You perhaps have the log enabled and the plugin can't write to this file path. Anyway the plugin should not crash, I will check it.
I suppose that if you disable the log to file option, or you set other file path, all should work fine.
juanjgon
Postby UglyStupidHonest » Fri May 13, 2016 2:53 pm
UglyStupidHonest Fri May 13, 2016 2:53 pm
worked thank you so much !!!
UglyStupidHonest
Return to Houdini
Tue Feb 25, 2020 7:23 pm [ UTC ]
