Install plugin problem
Houdini Integrated Plugin
Dmi3ryd
Hi everyone.
Could you help me please with next.
Trying toinstall plugin for houdini and set folders path:
On Windows, you need to set the PATH to point to the scripts/bin as well:
PATH = "C:/path/to/octane/bin;$PATH"
HOUDINI_PATH = "C:/path/to/octane;&"
What I need to place in houdini.env file?
PATH = "C:\Octane_2.25.0.1\bin;$PATH"
HOUDINI_PATH = "C:\Octane_2.25.0.1\bin;&"
I don't understand how write this correct.
My octane plugin placed in C:\Octane_2.25.0.1\bin
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
juanjgon
For a plugin placed in C:\Octane_2.25.0.1 you should set in your houdini.env file:
PATH = "C:/Octane_2.25.0.1/bin;$PATH"
HOUDINI_PATH = "C:/Octane_2.25.0.1;&"
Even in Windows, you have to use forward slashes (“/”) instead of backslashes as path separators.
Dmi3ryd
juanjgon many thanks for very fast reply.
Now my file contain:
# Houdini Environment Settings
# The contents of this file are read into the environment
# at startup. They will override any existing entries in
# the environment.
# The syntax is one entry per line as follows:
# VAR = VALUE
# Values may be quoted
# VAR = "VALUE"
# Values may be empty
# VAR =
# Example:
# HOUDINI_NO_SPLASH = 1
Is it correct?
Dmi3ryd
Demo version didn't work at Houdini Non-Commercial version?
juanjgon
Yes, the houdini.env file seems correct.
Anyway as far I know, the plugin requires Houdini, Houdini FX or Houdini Education. Houdini Apprentice and Houdini Indie cannot run the Octane plugin as they lack support for third party renderers.
Dmi3ryd
juanjgon thanks for you help!
Return to “Houdini”
