Hey juanjgon !
Is it possible to stick a texture to animated objects that are rendered in the "render" curve mode ?
If I use one of the noises for example with box mapping it sticks but if I use a texture with box mapping it does not?
Any idea why this happens ?
Thank you so much
regards
Chris
						Stick texture to curves
- UglyStupidHonest
Hey !
Yeah totally ! But somehow it won't read the uv's in curve mode !
here is the file :
https://drive.google.com/file/d/0B5TmRi ... sp=sharing
thank you!!
here is the file :
thank you!!
Yes, I see ... the problem is that Octane doesn't full support UV mapping in the curves at point level, each curve only can have one UV map value for all the curve segments, so the UV map is useless in this object to map a texture on it.
The texture using the box projection in object space doesn't stick to the object because you are animating the object at SOP level. This is for Octane a deformation effect, so the texture applied in object space is not fixed to the geometry. If you animate the object at OBJ level (in this case your object translation), the texture is going to stick to the object without problems.
In sort: currently the Octane curves don't support UV mapping at point level, so you can't stick a texture in this kind of objects if you are animating deformations in the mesh (transformations at SOP level, for example). You can stick a texture using any projection in object space if you animate the object at OBJ level, animating the transformation parameters.
- UglyStupidHonest
Ah I see!! Thank you very much for your help ! I will try to work around this then for now !!
						Hola Juanjo,
he abierto un hilo (viewtopic.php?f=30&t=65132&p=330621#p330621) para un problema parecido al de este.
Te resumo. Estoy importando un alembico que viene de Houdini (es una simulación de Organic tissue) y quiero renderizarlo en C4d. El problema es que me pasa como a UglyStupidHonest, la textura no sigue al objeto.
Creo que ya das la solución a eso (que no hay solución jajaja) pero no sé si ene estos dos años ha cambiado algo o no
Gracias por adelantado, saludos.
Nope sorry. Currently, we have the same limitation. The Octane curves don't support UV mapping at point level. There is a tool to manage a gradient along the curves length, but the full UV mapping is not possible. You can define a UV map, but only one for all the curve segments, at primitive level.
