What is the IPR update trigger?
Houdini Integrated Plugin
andrewprousalis
Any update on this? Forcing full reloads when the scene gets to be heavier (and consequently slow to reload) basically makes the renderer useless for lighting any serious work. Would be good to know if we should expect a plugin update soon or look for alternatives for heavier scenes. Thanks!
ricky_otoy
Hi Andrew, the bug is logged in the system already, but I cannot give you an ETA on a fix just yet.
andrewprousalis
Copy that. Thanks for digging into it!
seesharpstudio
Having the same problem. Unticked everything from the IPR update menu, having timeshift on every node - it's very difficult to work with. Can't move the light around because the scene has around 10 mil polys. It freezes like it reloads the whole geo in the scene when you move the light. What can I do?
ricky_otoy
seesharpstudio wrote:Having the same problem. Unticked everything from the IPR update menu, having timeshift on every node - it's very difficult to work with. Can't move the light around because the scene has around 10 mil polys. It freezes like it reloads the whole geo in the scene when you move the light. What can I do?
Can you send me the scene sample, we have fixed moving heavier geometry while IPR is running in the latest builds - are you using Full Scene reload at all, if so - rather revert to default as it isn't needed anymore.
seesharpstudio
Hi. Bruce help me fix it in the Release thread. It was the AI Light in the render target that made all the problems also with the lights and also with the emission on instances.
Return to “Houdini”
