OctaneRender for Modo SCRIPTS
Render passes are ignoring pass visibility. Using Modo native or Vray it is extremely useful to be able to toggle off a pass using the little camera icon in the groups panel. Say you have a dozen passes but three of them you do not need to run, it can save a lot of wasted time. When I run the script for Octane it renders all passes ignoring that state.
You should be able to tweak the code to do this. It will be something like adding the lines:
pass_state = lx.eval('layer.enable enable:?')
if pass_state == "off":
    continue
after the line
render_pass_group = modo.item.RenderPassGroup(current_pass_group_name)
Remember to make sure the indentation is correct. If you have trouble, please PM me the code and I will take a closer look.
Here is the latest version of the render pass rendering scripts. All previous version above have been removed.
#python
# NOTE: Make sure you select the correct file extension (png or exr) to match the current "Save Image" -> "Save Format" in the Octane plugin toolbar
import modo
import lx
# Only runs on Modo15/16
import PySide2
from PySide2.QtGui import *
from PySide2.QtCore import *
from PySide2.QtWidgets import *
from PySide2.QtWidgets import QFileDialog
# Get the file save name and location.  Enter the correct extension to match the Octane Save parameters (ie. .png or .exr)
path_to_file, _ = QFileDialog.getSaveFileName(None, "Save Files As...", None, "Images (*.png *.exr)")
if path_to_file != "":
   # Split the path into a filename/folder and an extension
   extension = path_to_file[path_to_file.rfind("."):]
   path_to_file = path_to_file[0:path_to_file.rfind(".")]
   # Get the currently select Pass Group
   current_pass_group_name = lx.eval('group.current ? pass')
   # Popup a progress window.  Remove the cancel button, as cancelling the render via the Render progress window should cancel all rendering
   progress = QProgressDialog("Rendering passes for " + render_pass_group.name, "Abort Rendering", 0, render_pass_group.itemCount, None)
   progress.setWindowModality(Qt.NonModal)
   progress.setWindowFlags(progress.windowFlags() ^ Qt.WindowStaysOnTopHint)
   progress.setCancelButton(None)
   progress.show()
   progress.move (progress.pos().x(), progress.pos().y() - 100)
   PySide2.QtWidgets.QApplication.processEvents()
   # Render and save each Pass in the current Pass Group
   action_clip_number = 0
   for action_clip in render_pass_group.passes:
      progress.setValue(action_clip_number)
      action_clip_number = action_clip_number + 1
      action_clip.active = True
      if action_clip.enabled:
          filename = path_to_file + "_" + action_clip.name +  extension
          try:
             result = lx.eval('octane.renderAndSave "' + filename + '"')
          except:
             break
   progress.hide()
Here is a variation on the above script which will export each pass to an ORBX file. IMPORTANT: Make sure the Octane Viewport is rendering prior to running this script.
#python
# IMPORTANT: Make sure the Octane Viewport is rendering prior to running this script.
import modo
import lx
import PySide2
path_to_file, _ = QFileDialog.getSaveFileName(None, "Save Files As...", None, "ORBX (*.orbx)")
   progress.show()
          try:
             result = lx.eval('octane.saveFrame "' + filename + '"')
          except:
             break
   progress.hide()
Hesekiel2517
I was looking for an octane alternative to modos variation texture in item mode. Here is a script that assigns a weightmap with unique values to selected meshes. You can then use these with a greyscale vertex attribute texture in octane.
# python
import lx
selected_items = lxu.select.ItemSelection().current()
x = 0
for item in selected_items:
	item_name = item.UniqueName()
	try:
		weight = x/(len(selected_items)-1)
	except:
		weight = 0
	lx.eval('select.drop item')
	lx.eval('select.subItem %s set mesh'%item_name)
	lx.eval('!vertMap.new Weight wght value:%f' %weight)
	print("Item Name: "+item_name + " Assigned Weight: " + str(weight))
	x = x+1
print("Processed Items: "+str(len(selected_items)))
Here is an alternative script that assigns a random seed value to each mesh. It's possible to use that with the random color texture in Octane. Thanks to funk for pointing that out.
# python
import lx
seed = 0
	try:
		lx.eval('item.channel oc_randomSeed %i'%seed)
	except:
		print("no randomSeed available")
	print("Item Name: "+item_name + " Assigned Seed: " + str(seed))
	seed += 1
I hope this is useful to someone.
Awesome - thanks for sharing.
Dingbat
face_off wrote:Here is the latest version of the render pass rendering scripts. All previous version above have been removed.
#python
import modo
import lx
import PySide2
   progress.show()
          try:
          except:
             break
   progress.hide()
any way to get this to work with MODO 14?
I believe that Modo14 uses python2, so I think you would need some good python coding skills to get these scripts working with Modo14. The Octane plugin is supported for Modo 15-17.
Return to “Foundry Modo”
