Octane for Softimage 1.04 RC4 Demo/Full [Obsolete]
Autodesk Softimage XSI (Developed by Face)
abeoctane
I dont use any custom script when rendering, It happened to me that I forgot to create a folder and send a sequence to render, octane didnt stop and keep rendering normally, but obiously it didnt saved any images, I dont have that problem with redshift.
abeoctane
I tried to unistall the old one first, and nothing, it only happens with 1.04 rc4.
face
abeoctane wrote:I dont use any custom script when rendering, It happened to me that I forgot to create a folder and send a sequence to render, octane didnt stop and keep rendering normally, but obiously it didnt saved any images, I dont have that problem with redshift.
When i drag&drop a .scn to the ScriptXSI.bat it will stop rendering if the image can´t save.
With xsibatch you will become:
G:\Softimage\Softimage 2013 SP1\Application\bin>xsibatch -render G:\Mein\Scenes\animTake1.scn
 Autodesk Softimage 11.1.57.0
License information: using [85934SFTIMSIB_2013_0F]
// INFO : C:\Users\face\Autodesk\Softimage_2013_SP1\Addons\emFluid4\Application\Plugins\
// INFO :
// INFO : C:\Users\face\Autodesk\Softimage_2013_SP1\Addons\emTopolizer2\Application\Plugins\
// INFO :
// INFO : Load OctaneRender« for Autodesk« Softimage« 1.04 RC4
// INFO :
COMMAND: -render G:\Mein\Scenes\animTake1.scn
>Loading: G:\Mein\Scenes\animTake1.scn...
// INFO : 4034 - Loaded scene was created with build number: 11.1.57.0 - compatibility version: 1100
OpenScene("G:\\Mein\\Scenes\\animTake1.scn", false, true);
// INFO : Rendering all passes: Passes.Default_Pass
// INFO : Rendering pass 'Default_Pass'...
// INFO : Rendering frame 1 (0.0% done)
// INFO : Initialize OctaneRender« for Autodesk« Softimage« 1.04 RC4
// INFO : Connect to OctaneLive.
// INFO : Valid OctaneLive license found.
// INFO :
// INFO : Set Geometry: sphere
// INFO : Cleanup Geometry
// INFO : Set Materials: Scene_Material
// INFO :
// INFO : Set Camera: Camera changed
// INFO : Set Environment: Environment changed
// INFO : Set GPU: GPU changed
// INFO : Set Kernel
// INFO : Set Output
// INFO : Set Resolution: Resolution changed
// INFO : Update Renderer
// INFO :
// INFO : Start Render
// INFO : Stop Render
// INFO :
// WARNING : Can┤t write to output Directory: p:\test!!
Where the render messages are new, but it stops with or without the messages.
http://vimeo.com/user2509578
abeoctane
Maybe a bug or something?, sometimes renders, sometimes dont.
face
abeoctane wrote:Maybe a bug or something?, sometimes renders, sometimes dont.
Hm, have installed the rc4 after i have uninstalled the rc3 and all worked, no black output when i render with a texture environment.
Also no crash in the preview or the render region if i change the geometry.
Ok, it was only a simple subdivided sphere. Maybe it happens if the scene is more complex.
The visual c redistributable dll you have installed i think, without it wouldn´t work.
abeoctane
Which version of visual c redistributable dll do you have?, because I get black render even with a sphere, maybe installing the same visual c version fix this problem, thanks.
face
You need the one which is linked in the first side:
https://www.microsoft.com/en-US/downloa ... x?id=48145
But there is nothing changed, so also the old plugins shouldn´t work without this dll, since 1.03.
abeoctane
Thats weird, 1.04 rc3 works, something else with the fixed bugs changed that is not working for me anymore, like the installation problem of the addon.
face
abeoctane wrote:Thats weird, 1.04 rc3 works, something else with the fixed bugs changed that is not working for me anymore, like the installation problem of the addon.
Can you try this octane.dat?
Copy it over the one in the addon directory.
Had changed it with the one from the standalone because this issue was solved:
viewtopic.php?f=29&t=54656
octane_dat.zip
(3.86 MiB) Downloaded 978 times
abeoctane
Hi face, sorry for the delay post, I had to finish a couple of projects and I didn't have time to test octane again until now, looks like the dat file fix the black render, thank you.
Return to “Autodesk Softimage XSI”
