Inventor Lights, Update materials
Autodesk Inventor (Integrated Plugin developed by Paul Kinnane)
Yes, pls send me the file.
frifer
i have sent you a PM with the download link
Thanks for sending through the file. The slow load time is due to the geometry being broken into tiny surfaces within Inventor. So the main model (pipes etc) has a total of 28348 small patches of polygon. It takes approx 0.2 of a second for Inventor to convert each of these geometry items to a mesh which can then be loaded into Octane. So 0.2 * 28348 / 60 / 60 = 1.57hrs to load that element. Regretfully there is nothing I can do at the plugin end to resolve this, because the plugin is simply processing the geometry elements provided by Inventor, and there are 28k of them, and they take 1.57/ hrs for Inventor to provide.
So the root cause of the problem is how that geometry is stored in Inventor. Is there an Inventor function which will allow you to combine those 28k patches into a single surface? Was that geometry item created by Inventor, or imported from another app?
I have detailed the debug output below so you can see the issue for yourself. Pls note that the times listed are for Inventor to mesh the surface patch. So 99% of your 1.5h load time is inside Inventor - not the plugin.
Sorry I cannot be more help....
Processed face 1 in 0.204 secs. Polygon count = 14
Processed face 2 in 0.202 secs. Polygon count = 6
Processed face 3 in 0.202 secs. Polygon count = 2
Processed face 4 in 0.202 secs. Polygon count = 6
Processed face 5 in 0.212 secs. Polygon count = 2
Processed face 6 in 0.2 secs. Polygon count = 6
Processed face 7 in 0.203 secs. Polygon count = 2
Processed face 8 in 0.203 secs. Polygon count = 6
Processed face 9 in 0.212 secs. Polygon count = 2
Processed face 10 in 0.203 secs. Polygon count = 14
Processed face 11 in 0.202 secs. Polygon count = 14
Processed face 12 in 0.2 secs. Polygon count = 6
Processed face 13 in 0.2 secs. Polygon count = 2
Processed face 14 in 0.204 secs. Polygon count = 6
Processed face 15 in 0.201 secs. Polygon count = 2
Processed face 16 in 0.206 secs. Polygon count = 6
Processed face 17 in 0.224 secs. Polygon count = 2
Processed face 18 in 0.204 secs. Polygon count = 6
Processed face 19 in 0.199 secs. Polygon count = 2
Processed face 20 in 0.202 secs. Polygon count = 14
Processed face 21 in 0.205 secs. Polygon count = 8
Processed face 22 in 0.203 secs. Polygon count = 2
Processed face 23 in 0.202 secs. Polygon count = 2
Processed face 24 in 0.202 secs. Polygon count = 4
Processed face 25 in 0.2 secs. Polygon count = 2
Processed face 26 in 0.203 secs. Polygon count = 2
Processed face 27 in 0.201 secs. Polygon count = 2
Processed face 28 in 0.203 secs. Polygon count = 2
Processed face 29 in 0.205 secs. Polygon count = 2
Processed face 30 in 0.201 secs. Polygon count = 2
Processed face 31 in 0.206 secs. Polygon count = 2
Processed face 32 in 0.201 secs. Polygon count = 4
Processed face 33 in 0.209 secs. Polygon count = 8
Processed face 34 in 0.202 secs. Polygon count = 8
Processed face 35 in 0.2 secs. Polygon count = 2
Processed face 36 in 0.202 secs. Polygon count = 2
Processed face 37 in 0.205 secs. Polygon count = 2
Processed face 38 in 0.203 secs. Polygon count = 2
Processed face 39 in 0.204 secs. Polygon count = 4
Processed face 40 in 0.203 secs. Polygon count = 2
Processed face 41 in 0.202 secs. Polygon count = 4
Processed face 42 in 0.226 secs. Polygon count = 2
Processed face 43 in 0.202 secs. Polygon count = 4
Processed face 44 in 0.204 secs. Polygon count = 2
Processed face 45 in 0.204 secs. Polygon count = 4
Processed face 46 in 0.204 secs. Polygon count = 2
Processed face 47 in 0.202 secs. Polygon count = 2
Processed face 48 in 0.203 secs. Polygon count = 2
Processed face 49 in 0.203 secs. Polygon count = 2
Processed face 50 in 0.207 secs. Polygon count = 2
Processed face 51 in 0.202 secs. Polygon count = 2
Processed face 52 in 0.203 secs. Polygon count = 15
Processed face 53 in 0.201 secs. Polygon count = 36
Processed face 54 in 0.202 secs. Polygon count = 18
Processed face 55 in 0.206 secs. Polygon count = 54
Processed face 56 in 0.203 secs. Polygon count = 7
Processed face 57 in 0.202 secs. Polygon count = 7
Processed face 58 in 0.203 secs. Polygon count = 18
Processed face 59 in 0.2 secs. Polygon count = 7
Processed face 60 in 0.21 secs. Polygon count = 4
Processed face 61 in 0.201 secs. Polygon count = 2
Processed face 62 in 0.203 secs. Polygon count = 2
Processed face 63 in 0.205 secs. Polygon count = 2
Processed face 64 in 0.201 secs. Polygon count = 2
Processed face 65 in 0.202 secs. Polygon count = 2
Processed face 66 in 0.223 secs. Polygon count = 2
Processed face 67 in 0.203 secs. Polygon count = 15
Processed face 68 in 0.208 secs. Polygon count = 36
Processed face 69 in 0.206 secs. Polygon count = 18
Processed face 70 in 0.207 secs. Polygon count = 54
Processed face 71 in 0.204 secs. Polygon count = 7
Processed face 72 in 0.201 secs. Polygon count = 16
Processed face 73 in 0.201 secs. Polygon count = 3
Processed face 74 in 0.205 secs. Polygon count = 3
Processed face 75 in 0.204 secs. Polygon count = 3
Processed face 76 in 0.204 secs. Polygon count = 3
Processed face 77 in 0.199 secs. Polygon count = 3
Processed face 78 in 0.204 secs. Polygon count = 4
Processed face 79 in 0.203 secs. Polygon count = 3
Processed face 80 in 0.207 secs. Polygon count = 3
Processed face 81 in 0.204 secs. Polygon count = 3
Processed face 82 in 0.208 secs. Polygon count = 3
Processed face 83 in 0.204 secs. Polygon count = 3
Processed face 84 in 0.201 secs. Polygon count = 16
Processed face 85 in 0.2 secs. Polygon count = 3
Processed face 86 in 0.203 secs. Polygon count = 4
Processed face 87 in 0.203 secs. Polygon count = 4
Processed face 88 in 0.199 secs. Polygon count = 4
Processed face 89 in 0.201 secs. Polygon count = 4
Processed face 90 in 0.199 secs. Polygon count = 3
Processed face 91 in 0.219 secs. Polygon count = 4
Processed face 92 in 0.204 secs. Polygon count = 18
Processed face 93 in 0.211 secs. Polygon count = 7
Processed face 94 in 0.203 secs. Polygon count = 7
Processed face 95 in 0.204 secs. Polygon count = 2
Processed face 96 in 0.204 secs. Polygon count = 2
Processed face 97 in 0.203 secs. Polygon count = 2
Processed face 98 in 0.207 secs. Polygon count = 2
Processed face 99 in 0.203 secs. Polygon count = 2
Processed face 100 in 0.215 secs. Polygon count = 2
Processed face 101 in 0.203 secs. Polygon count = 2
Processed face 102 in 0.202 secs. Polygon count = 2
Processed face 103 in 0.202 secs. Polygon count = 2
Processed face 104 in 0.204 secs. Polygon count = 2
Processed face 105 in 0.204 secs. Polygon count = 2
Processed face 106 in 0.205 secs. Polygon count = 2
Processed face 107 in 0.201 secs. Polygon count = 2
Processed face 108 in 0.205 secs. Polygon count = 2
Processed face 109 in 0.206 secs. Polygon count = 2
Processed face 110 in 0.204 secs. Polygon count = 2
Processed face 111 in 0.203 secs. Polygon count = 2
Processed face 112 in 0.201 secs. Polygon count = 2
Processed face 113 in 0.202 secs. Polygon count = 14
Processed face 114 in 0.207 secs. Polygon count = 6
Processed face 115 in 0.226 secs. Polygon count = 2
Processed face 116 in 0.204 secs. Polygon count = 6
Processed face 117 in 0.204 secs. Polygon count = 2
Processed face 118 in 0.205 secs. Polygon count = 6
Processed face 119 in 0.201 secs. Polygon count = 2
Processed face 120 in 0.204 secs. Polygon count = 6
Processed face 121 in 0.211 secs. Polygon count = 2
Processed face 122 in 0.209 secs. Polygon count = 14
Processed face 123 in 0.203 secs. Polygon count = 14
Processed face 124 in 0.203 secs. Polygon count = 6
Processed face 125 in 0.209 secs. Polygon count = 2
Processed face 126 in 0.204 secs. Polygon count = 6
Processed face 127 in 0.209 secs. Polygon count = 2
Processed face 128 in 0.202 secs. Polygon count = 6
Processed face 129 in 0.202 secs. Polygon count = 2
Processed face 130 in 0.202 secs. Polygon count = 6
Processed face 131 in 0.202 secs. Polygon count = 2
Processed face 132 in 0.201 secs. Polygon count = 14
Processed face 133 in 0.203 secs. Polygon count = 2
Processed face 134 in 0.202 secs. Polygon count = 2
Processed face 135 in 0.205 secs. Polygon count = 2
Processed face 136 in 0.2 secs. Polygon count = 2
Processed face 137 in 0.205 secs. Polygon count = 18
Processed face 138 in 0.203 secs. Polygon count = 7
Processed face 139 in 0.206 secs. Polygon count = 18
Processed face 140 in 0.231 secs. Polygon count = 7
Processed face 141 in 0.204 secs. Polygon count = 18
Processed face 142 in 0.204 secs. Polygon count = 7
Processed face 143 in 0.201 secs. Polygon count = 18
Processed face 144 in 0.205 secs. Polygon count = 7
Processed face 145 in 0.201 secs. Polygon count = 18
Processed face 146 in 0.203 secs. Polygon count = 18
Processed face 147 in 0.205 secs. Polygon count = 53
Processed face 148 in 0.208 secs. Polygon count = 18
Processed face 149 in 0.203 secs. Polygon count = 18
Processed face 150 in 0.204 secs. Polygon count = 18
Processed face 151 in 0.204 secs. Polygon count = 18
Processed face 152 in 0.2 secs. Polygon count = 18
Processed face 153 in 0.202 secs. Polygon count = 18
Processed face 154 in 0.202 secs. Polygon count = 11
Processed face 155 in 0.201 secs. Polygon count = 10
Processed face 156 in 0.205 secs. Polygon count = 14
Processed face 157 in 0.204 secs. Polygon count = 22
Processed face 158 in 0.208 secs. Polygon count = 38
Processed face 159 in 0.203 secs. Polygon count = 18
Processed face 160 in 0.199 secs. Polygon count = 6
Processed face 161 in 0.204 secs. Polygon count = 31
Processed face 162 in 0.202 secs. Polygon count = 6
Processed face 163 in 0.203 secs. Polygon count = 18
Processed face 164 in 0.223 secs. Polygon count = 3
Processed face 165 in 0.202 secs. Polygon count = 3
Processed face 166 in 0.206 secs. Polygon count = 3
Processed face 167 in 0.2 secs. Polygon count = 3
Processed face 168 in 0.207 secs. Polygon count = 13
Processed face 169 in 0.207 secs. Polygon count = 2
Processed face 170 in 0.203 secs. Polygon count = 2
Processed face 171 in 0.204 secs. Polygon count = 2
Processed face 172 in 0.203 secs. Polygon count = 2
Processed face 173 in 0.201 secs. Polygon count = 2
Processed face 174 in 0.201 secs. Polygon count = 2
Processed face 175 in 0.204 secs. Polygon count = 15
Processed face 176 in 0.202 secs. Polygon count = 18
Processed face 177 in 0.201 secs. Polygon count = 7
Processed face 178 in 0.202 secs. Polygon count = 4
Processed face 179 in 0.201 secs. Polygon count = 12
Processed face 180 in 0.203 secs. Polygon count = 4
Processed face 181 in 0.204 secs. Polygon count = 4
Processed face 182 in 0.2 secs. Polygon count = 27
Processed face 183 in 0.199 secs. Polygon count = 5
Processed face 184 in 0.201 secs. Polygon count = 5
Processed face 185 in 0.203 secs. Polygon count = 27
Processed face 186 in 0.205 secs. Polygon count = 18
Processed face 187 in 0.201 secs. Polygon count = 21
Processed face 188 in 0.205 secs. Polygon count = 18
Processed face 189 in 0.223 secs. Polygon count = 8
Processed face 190 in 0.202 secs. Polygon count = 3
Processed face 191 in 0.213 secs. Polygon count = 3
Processed face 192 in 0.204 secs. Polygon count = 8
Processed face 193 in 0.208 secs. Polygon count = 6
Processed face 194 in 0.207 secs. Polygon count = 3
Processed face 195 in 0.213 secs. Polygon count = 6
Processed face 196 in 0.206 secs. Polygon count = 3
Processed face 197 in 0.203 secs. Polygon count = 27
Processed face 198 in 0.209 secs. Polygon count = 5
Processed face 199 in 0.21 secs. Polygon count = 5
Processed face 200 in 0.2 secs. Polygon count = 27
Processed face 201 in 0.202 secs. Polygon count = 18
Processed face 202 in 0.203 secs. Polygon count = 21
Processed face 203 in 0.207 secs. Polygon count = 18
Processed face 204 in 0.21 secs. Polygon count = 8
Processed face 205 in 0.205 secs. Polygon count = 3
Processed face 206 in 0.207 secs. Polygon count = 3
Processed face 207 in 0.201 secs. Polygon count = 8
Processed face 208 in 0.202 secs. Polygon count = 6
Processed face 209 in 0.204 secs. Polygon count = 3
Processed face 210 in 0.229 secs. Polygon count = 6
Processed face 211 in 0.205 secs. Polygon count = 3
Processed face 212 in 0.207 secs. Polygon count = 18
Processed face 213 in 0.232 secs. Polygon count = 14
Processed face 214 in 0.211 secs. Polygon count = 4
Processed face 215 in 0.205 secs. Polygon count = 4
Processed face 216 in 0.202 secs. Polygon count = 4
Processed face 217 in 0.203 secs. Polygon count = 4
Processed face 218 in 0.206 secs. Polygon count = 13
Processed face 219 in 0.207 secs. Polygon count = 3
Processed face 220 in 0.201 secs. Polygon count = 3
Processed face 221 in 0.202 secs. Polygon count = 3
Processed face 222 in 0.203 secs. Polygon count = 3
Processed face 223 in 0.211 secs. Polygon count = 18
Processed face 224 in 0.205 secs. Polygon count = 18
Processed face 225 in 0.207 secs. Polygon count = 18
Processed face 226 in 0.2 secs. Polygon count = 7
Processed face 227 in 0.203 secs. Polygon count = 18
Processed face 228 in 0.205 secs. Polygon count = 7
Processed face 229 in 0.204 secs. Polygon count = 18
Processed face 230 in 0.202 secs. Polygon count = 7
Processed face 231 in 0.208 secs. Polygon count = 18
Processed face 232 in 0.212 secs. Polygon count = 7
Processed face 233 in 0.212 secs. Polygon count = 2
Processed face 234 in 0.205 secs. Polygon count = 6
Processed face 235 in 0.208 secs. Polygon count = 6
Processed face 236 in 0.206 secs. Polygon count = 2
Processed face 237 in 0.243 secs. Polygon count = 2
Processed face 238 in 0.207 secs. Polygon count = 6
Processed face 239 in 0.213 secs. Polygon count = 6
Processed face 240 in 0.208 secs. Polygon count = 2
Processed face 241 in 0.207 secs. Polygon count = 6
Processed face 242 in 0.207 secs. Polygon count = 2
Processed face 243 in 0.203 secs. Polygon count = 6
.... etc until face 28348
Return to “Autodesk Inventor”
