Octane for Softimage 1.02 RC12 [Obsolete]
Hi face, I found another problem with the octane texture environment, because I want to animate the rotation of the HDRI, the problem is that when I set a key It does nothing, could you please fix this?, do you have an expected release of a stable version of this plugin for softimage?, maybe before some extra features that are you programming?, thanks a lot.
I´m working on some things, but i think i can make a build.abeoctane wrote:Hi face, I found another problem with the octane texture environment, because I want to animate the rotation of the HDRI, the problem is that when I set a key It does nothing, could you please fix this?, do you have an expected release of a stable version of this plugin for softimage?, maybe before some extra features that are you programming?, thanks a lot.
face
http://vimeo.com/user2509578
Have send you a messageface wrote:I´m working on some things, but i think i can make a build.abeoctane wrote:Hi face, I found another problem with the octane texture environment, because I want to animate the rotation of the HDRI, the problem is that when I set a key It does nothing, could you please fix this?, do you have an expected release of a stable version of this plugin for softimage?, maybe before some extra features that are you programming?, thanks a lot.
face
face
A little info for the next version.
The render tree will be back and will look how it should.
There will be also other significant changes, but you will see...
face
face
- Elvissuperstar007
- Contact:
wow!
direct storm among the clear sky
you need to find a good visualiser for lessons Octane for Softimage
the program XSI is still popular but you have a bad advertising campaign
win 7 /64x C2Quad 6600 2.4/ Nvidia 9800 GX2 1gb 512 bit + Asus 480 GTX/ DDR2 8Gb / NVIDIA 460 GTX 2GB/2x NVIDIA 580 GTX 3GB
- wireframex
I am following the evolution of the plugin with interest.
Hope to have something close to version 3.0 of the Octane Core soon
Main Computer:
Ryzen 3990X / 96Go Ram / 2 x RTX 3090
OS: Windows 11 x64 - NVidia Driver 560.70 - Octane Plugin Build 2023.1.3.141
Licensed: Softimage 2012 SP1 / Lightwave 2024.0.1 / Rhino 8.9
A little video, with the new feature that compounds are included.
Compounds are realy realy evil to code.
Have spend hours for this weird little pice of software. In the end i have used an xml parser to get the compound infos i need.
Now i will try to get the compound input parameters when no source node is connected in.
But hope you like it,
face
http://www.vimeo.com/156739814
face
- wireframex
Hi Face,
Nice video and well done for the shaderball support.
Please don't forget to save your work
Regard
Regard
Main Computer:
Lol, thanks.wireframex wrote:Hi Face,
Regard
Every day a backup is scheduled
face
The final part of the shaderball is done.
It wasn´t so simple to integrate the gradient shader and the connections. It has used the most time.
The previous shaderball couldn´t use the compound parameters, which is now done.
I think it is finished and time to make other things...
Here a little video, hope you enjoy,
face
http://www.vimeo.com/158947144
edit:
I can´t play any video on Vimeo, so it´s possible theres a problem with the server...
face
edit:
