Which feature do you need the most?
Region Render
139
6%
Network render
84
4%
Render Passes
238
11%
Hair&Fur
286
13%
Particles
228
10%
Multilight
155
7%
Internal Texture Mapping (planar, box, spherical, cylindrical, camera and so on)
86
4%
Undo
104
5%
Volumetric: fire, smoke, clouds
369
16%
Mixing of daylight and HDRI environment
211
9%
Subdivision surfaces (OpenSubDiv)
80
4%
Multi UV channels
129
6%
Rounded edges
130
6%
Total votes: 2239
e-s
PRG Clear Sky Daylight model would be so nice. That's what Vray and Corona use, and it looks great
skientia
e-s wrote:PRG Clear Sky Daylight model would be so nice. That's what Vray and Corona use, and it looks great
It's seemingly not much different from Nishita / Planetary. Any paper available? Documentations from these mentioned renderers are not informative.
e-s
skientia wrote: It's seemingly not much different from Nishita / Planetary. Any paper available? Documentations from these mentioned renderers are not informative.
Admittedly, I don't understand all of the technical nitty-gritty, but here is a link to the paper and presentation from SIGGRAPH:
https://cgg.mff.cuni.cz/publications/skymodel-2021/
e-s
I had posted this request in the C4D section but was informed that it's a limitation of OctaneCore, so I'm reposting here.
It would be great to have a streamlined workflow / UI for light linking. I think Redshift is a good reference here, where each light has a tab that can exclude/include specific objects - it's fast and straightforward to use with a couple of clicks, and easy to understand which lights are affecting each object.
noldo
It would be very interesting to implement a function that generates a Gaussian splat cloud from a 3D model.
The advantage would be real time navigation including reflections and transparencies, which, especially in VR environments, would be great.
I think that Gaussian splat works by adding color information to each individual point of the cloud in relation to the viewing angle, thus allowing a point to take on multiple aspects depending on how you look at it.
Obviously this information, which current software generates from photos or videos captured from different angles, could be generated by the rendering engine.
In essence, the rendering engine would have to divide the model into many small equidistant points lying on the faces and calculate for each of them the information coming from the various directions.
This would lead to a Gaussian splat environment that is enormously more precise than anything that can be generated with photos and above all observable from any point of view.
