OctaneRender® beta 2.43 (lin/mac/win) [OBSOLETE]
yoyoz
Actually it seems the '-r' command-line option (relink) is completely ignored by Octane.
I'd would be nice Marcus have a look at that...
Desktop: Ubuntu 13.04 x64 - i7-3770K @ 3.5GHz - 32GB DDR3 - GTX670 2048MB
Laptop: Linux Mint 11 x64 - i7-2860QM @ 2.5GHz - 16GB DDR3 - Quadro 3000M 2GB
Software: NVidia 319.12 - Cuda 4.2.9 - Blender 2.66a
dave62
hi marcus.
due to high frequent crashes while rendering with cuda3.2. i changed to the cuda 3.0 version:
cant say if anythink works more stable, because if i load the same ocs file with 3.0 mostly all material is lost/mixed up!???
real strange :shock: ???
so i stepped back again to cuda3.2, file loads completely correct again. ..but crashes somehow often (longest time up was under 1,5h) sadly not enough for firefly free pathtracing of my scene.
the crashes happen mostly without any notice, just simply closing.
is there any debug info mode/option to be started from terminal?
cheers dave
still on ubuntu64 10.10
- Mint 10 64bit nvidia drv 260.19.29/cudatoolkit3.0 intel q6600, 4gbRAM, GTX470 1,2GB
- Mint 10 64bit/ Win7 64bit nvidia drv 260.19.29/cudatoolkit3.2 amd X6, 16gbRAM, 2x GTX580 3GB
->Octane 2.44/ Blender2.5x
gvnwst
I'm having odd issues... The error window (attached screenshot) comes up every time I try to run the Cuda 3.2 version, even though I have Cuda 3.2 installed.
When I try running the 3.0 version, it loads...until I punch in my Live user account information. It says "Cannot Connect to Live Server" and retries over and over. It's not my firewall or Antivirus (I still had the problem after disabling both).
Any ideas?
GTX560Ti 2GB | i5 2.66 Quad | Win7 x64 | 12GB DDR3
abstrax
gvnwst wrote:I'm having odd issues... The error window (attached screenshot) comes up every time I try to run the Cuda 3.2 version, even though I have Cuda 3.2 installed.
Any ideas?
On Windows you do NOT have to install any CUDA toolkits or drivers. Just install the latest NVIDIA graphics driver (266.58) and it should work without problems.
Marcus
abstrax
yoyoz wrote:Actually it seems the '-r' command-line option (relink) is completely ignored by Octane.
Sorry, but it does not get ignored. Could you please post a scene that shows the problem? I also need the command line that is used to launch Octane, because I can't reproduce the problem here and relinking works as far as I know with the C4D exporter.
One important thing to know: Relinking happens via material names. -> The name of materials must not change between two exports.
Marcus
Aenima
@gvnwst: I have the same issue but on linux. You have internet connection and you can ping live1.refractivesoftware.com? If yes, try to login customer area and deactivate octane. Wait 30 mins and run again. Imho some problem about the licence checking and we get wrong error message.
W10 x64 32GB, EVGA GTX960 - EVGA GTX1060 - OSX 10.12.5 - CORE I5 3.4GHz
abstrax
matej wrote:I'm still getting all (most) of my macro to mesh connections messed up, when I add or remove a material in Blender and then re-export. I thought this was solved? I'm using Blender2.49b with the official exporter.
Regarding the first issue: I still need an example that shows the problem, because I can't reproduce it here.
Marcus
abstrax
dave62 wrote: the crashes happen mostly without any notice, just simply closing.
cheers dave
Sorry, no debug mode and please don't mix several things together. Let's try to untangle that mess:
- What does "messed up" mean? Does it mean that they are rendered incorrectly or that the materials have incorrect settings after loading from the OCS file?
- Are the test scenes rendered/loaded correctly?
- Why do you mean that the CUDA 3.0 build is no more stable than the CUDA 3.2 build? Does it crash, if yes when?
- When you use the CUDA 3.0 build - do you also remove the CUDA 3.2 toolkit and install the CUDA 3.0 toolkit?
- Have you been doing anything else while rendering on the computer?
- Do other scenes (like the test scenes) render correctly and longer than 1.5h?
- What do you see in the terminal if you launch Octane via command line and it crashed?
- Again, could you please send us a scene that makes Octane crash while rendering?
Sorry for the many questions, but if we want to make things more stable, we have to find, isolate and fix the culprit(s) which is impossible without more information.
Marcus
yoyoz
abstrax wrote:Sorry, but it does not get ignored. Could you please post a scene that shows the problem? I also need the command line that is used to launch Octane, because I can't reproduce the problem here and relinking works as far as I know with the C4D exporter.
Marcus
I suspect a difference between the 2 builds (cuda 3.0 and cuda 3.2) but I need to investigate furthermore to confirm. Do you prefer I upload the results here or via a PM?
Lionel
matej
Marcus
Well, it's happening with my competition scene, which is huge and I can't post it. When I'm finished with it, I'll create a test scene and a reproducible procedure, if I'll still experience any problems.
cgmo.net
