Also heads up Juanjo: although you write (and presumably speak) English as if it was your native tongue, you consistently say one thing that always sticks out, and blows your cover: "Thanks for report it".... Thanks for reporting it - is what you want.
OctaneRender™ 2.1 for LightWave™ - Daily builds
- FrankPooleFloating
Yes J, thanks so much for fixing the IPR zoom/scroll etc.
						- gordonrobb
Thanks for report it Frank
						Thanks for reporting itFrankPooleFloating wrote:Yes J, thanks so much for fixing the IPR zoom/scroll etc.![]()
My English isn't very good, I am glad that at least all people can understand me
juanjgon wrote:Thanks for reporting itFrankPooleFloating wrote:Yes J, thanks so much for fixing the IPR zoom/scroll etc.![]()
Dino Inglese
CG Artist
Melbourne Australia
Octane build 4.04.0.145
						CG Artist
Melbourne Australia
Thanks Juan, yeah I figured as much when I was making the test scene:)juanjgon wrote:Carlo, the problem is the Mix Texture node. The issue is that the render target nodes (both Texture and Daylight environment) only supports the texture rotation transformations if the Image Texture node is directly linked to their texture inputs. If you put any node between the image and the render target nodes, the rotation parameters don't work.Godstrike wrote: Please see attached. Looking at my nodes while making the test scene, I see the problem presents itself when you are mixing HDRIs.
You only need to remove the texture mix node to be able to rotate the HDRI backgrounds.
Any chance that the heading info could be piped through the intermediate node in a future release?
Carlo
Ryzen 5800x at 4.4GHz | 32GB | 1 x 3090 ti | 1 x RTX 2080 ti
						Antti, I am testing your 99% problem here with your render target file and I am not able to reproduce itatnreg wrote: -this is old problem but it is so serious that I now make the max. samples to use way over needed and then always do Abort+Cont because if I let the render go to the end, LW gets in not responding state often (the 99% problem), not always but too often.
Antti
Today or tomorrow I am going to release a new daily build (2.13.0) with the last Octane API core. Please test your problem with this new build to see what happens. If this build doesn't fix your issue I am going to need one of your full scenes here to test it.
Muchos gracias. One question regarding this build being optimized for the newer Maxwell CPU's.. will this effect the performance of older GPU's, namely my gtx590/580?
							Dino Inglese
CG Artist
Melbourne Australia
						CG Artist
Melbourne Australia
From the standalone release notes:MrFurious wrote:Muchos gracias. One question regarding this build being optimized for the newer Maxwell CPU's.. will this effect the performance of older GPU's, namely my gtx590/580?
"Until now, Octane kernels were compiled with CUDA 4.0, which provides a compiler based on Open64. With CUDA 4.1 NVIDIA introduced a new compiler based on LLVM, which produced totally different output and made Octane 10-15% slower. On the other hand, GPUs of newer compute models (like Maxwell) couldn't be built with CUDA 4.0. So we had to use a mix of different toolkits to support the various GPU architectures. Another problem was that on Mac OS you could either use only CUDA 4.0 on Xcode 3 or CUDA 4.1 (or higher) on Xcode 4 (or higher), effectively prohibiting the toolkit mix we used on Windows and Linux (which is the reason why OSX builds didn't have Maxwell support yet).
To fix all that mess and to allow us to do some interesting things in the future, we really needed to switch to a recent toolkit. It took us 3 tries to adapt the code for CUDA 6.5 without a too big performance loss. Since the output of the LLVM based compiler is very different from the old Open64 based compiler (CUDA 4.0), most scenes will render with slightly different speeds compared to version 2.12.1. Some scenes will be faster while others will be slower. It's hard to say what exactly works better/worse, but as a general trend, scenes with instances (i.e. most scenes) often render a bit faster in DL and PT, while single mesh scenes (like the old benchmark) render a bit slower in DL and PT. PMC seems to be a bit slower in most cases. Maxwell 2 GPUs got a lot faster (because of the switch and other optimizations)."
