Beta 2.2 RC1: Blender 2.49 Export Script testing thread
Locked
radiance
kivig wrote:Are texture sequences supported?
they should be, provided you preconfigure your material in blender so it appears correct at import.
Radiance
matej
Octane (beta 2.2) crashes on startup if it's fed an empty .obj file (ie. no vertex data). This happens in cases when "selection only" is enabled in the exporter, but no mesh objects are selected in the viewport. It should warn the user about nothing being selected.
EDIT:
Additionally, Octane crashes on startup always for me if I have enabled "GPU devices to use". I have one GPU.
cgmo.net
matej
The script directly translates the Blender "lens" camera parameter (supposed to be in mm?) to Octane "aperture" (supposed to be in cm?), if automatic population of the camera export values is done with the "select" button (export configuration), resulting in a totally blurred scene.
cgmo.net
matej
I get properly loaded textures in Octane only if I use "copy images". Does the .mtl file not support absolute paths to images?
Also sometimes the exporter creates materials that are not really there. In the .mtl file the "ghost" material has a name <actual material name>_<name of first texture in actual material texture channel>, for example:
If I have a material named 'MAT_testgrid' which has a texture on the diffuse channel named "testgrid.C.png", the "ghost" material has the name 'MAT_testgrid_testgrid.C.png' and its parameters are equal to MAT_testgrid. I have not been able to pinpoint what triggers this bug.
cgmo.net
enricocerica
I'll have a look to those points.
http://www.myline.be
kivig
Radiance
Only way I can get texture at all is by putting textures into octane project folder and setting "R" flag on the export, but it erases all the materials!
And it seems to change texture frame only upwards - If i render say frame 5, then frame 1 i get frame 1 with textures of frame 5.
Plus it doesn't works with animation, so no use of sequence...
http://www.visnevskis.com
Vista64/Ubuntu, GTX470/580
madcoo
radiance wrote:The fixing of project name with spaces (my project -> my_poject) was broken, it is fixed again
Hi !
I tried it just now, problem is: I can't get the project name to work... :(
My path starts with e:/Mes images/etc... and it keeps telling me there's a space in the name, and can't load it...
Any help more than welcome guys !
Cheers !
2011 New Year Competition - 2nd Prize winning image
Visit my website: Fairview Studio 3D - Facebook page
i7 Quad-Core 2.67Ghz / 16Gb RAM / Windows 7 64bits / 2x GTX 680 / Octane v2.0 / CUDA Driver 6.0
enricocerica
Hi !
Cheers !
You just can't have any space in the project path and in the project name, spaces are allowed only in the binary path. I'll investigate that issue but it seems that spaces are not accepted in the octane command line, at least from Blender python script and under Windows.
Sorry for that but for now you should manage to have a project path without any space.
Edit:If spaces are used in the project name, they are automatically converted to undersoce car, this is not the case for the path.
madcoo
Oh that's a shame... :?
Well, I'll have to get used to it then...
Thanks for your kind reply!
One more question though...
I want to animate an OBJ that I rendered before, just using Octane.
How do I "tell" Octane to go and fetch the OBJ file and the Material data that I want to use?
Many thanks in advance !
madcoo
Sorry, I didn't notice there were about 15 pages explaining all this in detail !!!!
:mrgreen:
Locked
Return to “Blender”
