No, you don't get 2x less noise, you get rid of practically all noise. That's what the blend mode "Darken" does, it only replaces the bright spots. And it FULLY replaces them, it's not a 50/50 mix.radiance wrote:this is the 2x render technique, it's already done before a long time ago, if i remember correctly, a few years ago.
offcourse it's not fun having to render the image twice, although if you let them render each the same time and mix them 50/50 you will get 2x less noise.
Brand new way to kill hot pixels
Apart from the fact that hot pixel applications lose image detail (they don't replace the hot pixels by actual rendered samples), how about someone post one that can be used for animation.
This may be useful for frames of animation which turned out too noisy. You just re render those frames and merge them together.
n1k
n1k
I tried this method but octane renders the exact same images, with fireflies and noise at the same placeradiance wrote:this is the 2x render technique, it's already done before a long time ago, if i remember correctly, a few years ago.
Radiance
Win7 x64 - I7 920@4Ghz - 6Go DDR3 - GTX470
Done it... I think.
http://www.refractivesoftware.com/forum ... =21&t=2597
If we consider fireflies a defect not a detail, with this shouldn't lose any detail at all:Chris_TC wrote:Apart from the fact that hot pixel applications lose image detail (they don't replace the hot pixels by actual rendered samples), how about someone post one that can be used for animation.
http://www.visnevskis.com
Vista64/Ubuntu, GTX470/580
yeap, Proupin explained it very well here http://www.refractivesoftware.com/forum ... f=6&t=1773 and it's a good technique, but it does kill the fun to take the same shot several times even thou it's not much more time.
Hi all.
I use similar technic sometimes, but I don't use darken blending. I make in few steps 1 or 2 masks from combinations of this two renders. With this technique ist the residual hoise beter as if you use only darken and is posible use the 2-th render only with 10 percents of samples or both with 50 percents of desired samples.
If you will use two renders with the same kvality (50 percent of desired samples for both), paste these two renders in photoshop in two layers and make the upper invert and set te opacity at 50 percent. Merge these two layers and curent result ist the mask which I use for outmasking fireflies. Now paste these two renders one more in two layers and aply the mask for the upper. If are fireflies stil in the result, make the mask as invert.
Is posible ad the contrast for the mask for better result.
Win Vista 64 | Phenom II X4 905e |Gigabyte GTX690 and zotac Geforce GTX260 | 8GB
The litle imprecision of both these technics ( masking and darken blending ) is the fact that in very noisy parts of renders ist the result a bit darker as the corect result.
