Autodesk Revit (Integrated Plugin developed by Paul Kinnane)
Postby JoGo23 » Fri Mar 29, 2024 1:50 pm
JoGo23 Fri Mar 29, 2024 1:50 pm
You need to have the 2024_Alpha_3 on both sides.
JoGo23
Postby mitchino » Fri Mar 29, 2024 1:56 pm
mitchino Fri Mar 29, 2024 1:56 pm
mitchino
Postby mitchino » Fri Mar 29, 2024 2:19 pm
mitchino Fri Mar 29, 2024 2:19 pm
mitchino
Postby bepeg4d » Tue Apr 02, 2024 7:18 am
bepeg4d Tue Apr 02, 2024 7:18 am
https://render.otoy.com/customerdownloa ... de_win.exe
Happy Mac Net GPU rendering!
ciao,
Beppe
Postby mitchino » Tue Apr 02, 2024 7:23 am
mitchino Tue Apr 02, 2024 7:23 am
Many thanks Beppe!
mitchino
Postby shtl_1 » Thu Apr 18, 2024 2:55 pm
shtl_1 Thu Apr 18, 2024 2:55 pm
Hello.
shtl_1
Postby bepeg4d » Fri Apr 19, 2024 6:36 am
bepeg4d Fri Apr 19, 2024 6:36 am
shtl_1 wrote:Hello.
ciao,
Beppe
Postby antondenisov » Thu May 09, 2024 3:42 am
antondenisov Thu May 09, 2024 3:42 am
Hey
I'm trying to connect my PC via network render to a Mac as a slave.
I have already installed the daemon on Windows, but when I try to click "Network Preferences" in the Octane settings on a Mac, nothing happens.
And there should be a window with machines available on the network.
What is the problem?
I have a MacBook Pro M2 and octane 2023.1.2 (R7)
antondenisov
Postby Delizade » Thu May 09, 2024 4:29 am
Delizade Thu May 09, 2024 4:29 am
Try to disable firewall completely.
I experienced similar network problem recently.
I
Windows can something but can’t get answer something :) I guess my problem was like that. I could not fix firewall settings yet but it worked for me.
Windows 10 (3090Ti) | MacBook Pro (M3 Max)
Delizade
Postby bepeg4d » Thu May 09, 2024 5:38 am
bepeg4d Thu May 09, 2024 5:38 am
antondenisov wrote:Hey
Please note that c4doctane 2023.1.x versions don't have Network Rendering feature enabled.
You need a 2024.1-Alpha version to be able to use Network Rendering with Apple Silicon.
Latest version is 2024.1-Alpha4, here is the link to c4doctane plugin:
https://render.otoy.com/customerdownloa ... _4_OSX.zip
And the link to corresponding Render Node version for Windows:
And Render Node for Linux:
Happy Net GPU rendering!
ciao,
Beppe
Previous
Return to Autodesk Revit
Fri May 17, 2024 9:59 pm [ UTC ]
