Frames being Overwritten
Forums: Frames being Overwritten
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby EyasArraf » Mon Mar 11, 2024 5:45 pm
EyasArraf Mon Mar 11, 2024 5:45 pm
When using a hou.frame() Python expression instead of the Hscript '$F' in the 'image file path' parameter, the python expression is evaluated as 1 for all frames and results in frames being overwritten on one another.
This problem does not occur in other ROP nodes like Mantra or Karma.
* Currently using:
Windows 11
Houdini 20.0.590
Octane 2024.1.2.0
EyasArraf
Re: Frames being Overwritten
Postby ricky_otoy » Mon Mar 18, 2024 12:16 pm
ricky_otoy Mon Mar 18, 2024 12:16 pm
EyasArraf wrote:When using a hou.frame() Python expression instead of the Hscript '$F' in the 'image file path' parameter, the python expression is evaluated as 1 for all frames and results in frames being overwritten on one another.
* Currently using:
Windows 11
Houdini 20.0.590
Octane 2024.1.2.0
Hi EyasArraf,
you mention $F not $FF, I think the equivalent is hou.intFrame() - does that give the same issue for you?
ricky_otoy
Postby EyasArraf » Tue Mar 19, 2024 11:04 am
EyasArraf Tue Mar 19, 2024 11:04 am
Actually hou.intFrame() equals = int(hou.frame()) and I tried both. Still the same problem. Both python expressions evaluate as "1" to every frame in the animation. Only happens in OctaneROP.
The reason I use Python instead of Hscript in this OctaneROP is that python is much more versatile and powerful when automating exporting frames.
I actually don't know if I'm the only one having this problem or what but I hope it gets fixed.
Thanks for your efforts.
EyasArraf
Postby ricky_otoy » Fri Mar 22, 2024 8:30 am
ricky_otoy Fri Mar 22, 2024 8:30 am
EyasArraf wrote:Actually hou.intFrame() equals = int(hou.frame()) and I tried both. Still the same problem. Both python expressions evaluate as "1" to every frame in the animation. Only happens in OctaneROP.
We are still looking into this, I will get back to you on it. Again sorry for the inconvenience!
ricky_otoy
Postby EyasArraf » Wed Apr 24, 2024 10:01 am
EyasArraf Wed Apr 24, 2024 10:01 am
I just downloaded Octane 2023.1.3.0 version. Thanks for fixing the issue. Appreciate it.
EyasArraf
Return to Bug Reports
Mon Jun 03, 2024 2:52 pm [ UTC ]
