OctaneRender 2022 for ArchiCAD [OBSOLETE]
Forums: OctaneRender 2022 for ArchiCAD [OBSOLETE]
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
Postby face_off » Tue Nov 22, 2022 4:26 am
face_off Tue Nov 22, 2022 4:26 am
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for ArchiCAD TEST and STABLE releases.
SOLUTIONS TO COMMON ISSUES
1) Make sure your NVIDIA drivers are up to date.
2) How do I extract the ArchiCAD 23 (or 24, 25 or 26) textures from the ArchiCAD 23 Library - 'File'->'Libraries and Objects'->'Extract a Container'. Select C:\Program Files\GRAPHISOFT\ARCHICAD 23\ARCHICAD Library 23\Surface Catalog 23.lcf to extract to Documents\AC23SurfaceCatalog. Then add the library to the Library Manager.
ArchiCAD Version
This version of the plugin runs on ArchiCAD 24, 25 and 26 - 64 bit Windows (7, 8, 10 and 11).
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 451 or higher.
Is there a macOS version of the plugin? - at this point in time there is no macOS version of the plugin. Given the large amount of effort it would take to migrated the plugin to macOS, and the small potential audience for the macOS plugin, I do not think there will be a macOS version in the foreseeable future.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using..
Support Issues
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- ArchiCAD version (ArchiCAD -> Help -> License Information -> Version and Build Number
- OctaneRender for ArchiCAD version (ie. 1.02a)
- In the unlikely event of a crash, pls provide the dump report from the C:\Users\[username]\Graphisoft\BugReporting-[version] folder (on Win 7). Either post or email (to "paul at physicalc-software.com") the "ArchiCAD-XXXXXX-FATAL.RPT" file from this folder.
For more information
- Read the on-line manual
- Read the FAQ
- Watch Tapperworks Showcase Part 1, Part 2 and Part 3
- Watch Tapperworks Render Passes video http://youtu.be/sXnLcWEbbmY
- Watch the Grass Generation video http://vimeo.com/113454418
- Post your question on this forum thread
Download Links
Once you save a .pla/.pln scene with the Octane 2022.1 version of the plugin, you may no longer be able to open the OctaneRender plugin with that scene loaded in ArchiCAD with a plugin compiled with an earlier version of Octane, so please keep separate copies of your scenes for Octane 2021.1 and Octane 2022.1.
Current TEST build (Octane 2022.1.1)
Previous TEST build (Octane 2022.1)
Release Notes
2022.1.1.115 (29-Apr-2023)
- Compiled with Octane 2022.1.1
- Added the option to save as 16 bit when saving all render passes
2022.1.0.114 (28-Nov-2022)
2022.1.0.113 (22-Nov-2022)
- Fixed is where new node types added for Octane 2022.1 were not showing
2022.1.0.112 (22-Nov-2022)
- Compiled with Octane 2022.1 RC3
- Implemented the Octane 2022.1 change "Image nodes now have a Border mode for U and V separately."
- Added Textures->Fields nodes
- Added C4D noise nodes
- Added Values->Utility nodes
- Added the Photon Tracing Kernel
- Removed the Imager->Pre-Multiplied Alpha pin, as this is no longer used with Octane 2022.1.
- Added new Texture nodes from Octane 2022.1 XB2
- Added the Curvature Visibility property from Octane 2022.1 XB3
- Added new texture nodes from Octane 2022.1 XB4
- IMPORTANT: Octane 2022.1 changes the way the Daylight Environment renders, and changes the way volumes render, so old scene using either of these Octane features may render differently
Re: OctaneRender 2022 for ArchiCAD [TEST and STABLE]
Postby face_off » Tue Nov 22, 2022 7:18 am
face_off Tue Nov 22, 2022 7:18 am
I have updated the installers at the top of this thread with:
2022.1.0.113
Postby Daniel_Ward » Fri Nov 25, 2022 1:35 am
Daniel_Ward Fri Nov 25, 2022 1:35 am
Hi Paul,
have been playing around with it for a bit and no issues I've observed so far thanks.
The new Octane Daylight environment produces very nice lighting, will hopefully reduce our reliance on rendering with HDRi environments and with faster results too!
Life should be a bit easier for you now with just the one subscription type to compile plugins for!
Cheers, Dan.
+MAP Architects, Christchurch - New Zealand
ArchiCAD 4.12 - ArchiCAD 24 || Octane for ArchiCAD
i7-7700K - Gigabyte Aorus Z270X Gaming 9 - 32Gb RAM - 3x Gigibyte GTX1070 G1 Gaming - Window 10 64Bit
Daniel_Ward
Postby face_off » Mon Nov 28, 2022 4:48 am
face_off Mon Nov 28, 2022 4:48 am
2022.1.0.114
As per Dan's comment above - there is no longer an Enterprise version - use the Studio+ installer instead.
Postby Dingbat » Mon Dec 19, 2022 11:56 am
Dingbat Mon Dec 19, 2022 11:56 am
thanks Paul
great to have fast caustics in AC now
Dingbat
Postby face_off » Sat Apr 29, 2023 3:29 am
face_off Sat Apr 29, 2023 3:29 am
2022.1.1.115
Postby Daniel_Ward » Sun Apr 30, 2023 8:41 pm
Daniel_Ward Sun Apr 30, 2023 8:41 pm
Hi Paul,
thanks for that.
I can download the AC24 and 25 installers, however the link to the AC26 installer has an issue and reports the file is missing?
Cheers, Dan.
Daniel_Ward
Postby face_off » Sun Apr 30, 2023 10:55 pm
face_off Sun Apr 30, 2023 10:55 pm
Daniel_Ward wrote:Hi Paul,
thanks for that.
Cheers, Dan.
Thanks Dan - it should be fixed now. Can you try again please?
Postby yllar » Fri May 05, 2023 5:39 pm
yllar Fri May 05, 2023 5:39 pm
Hi Paul,
Not sure if this is a right place to write, but it doesn't make sense to make a new topic. It seems I can't find the Render AOV z-depth inside the plugin.
Yllar
yllar
Postby face_off » Sat May 06, 2023 12:04 am
face_off Sat May 06, 2023 12:04 am
yllar wrote:Hi Paul,
Yllar
Hi Yllar - this version should fix this problem. https://render.otoy.com/customerdownloads/plugins/b6/ea/9e/81/OctaneRender_for_ArchiCAD26_2022_1_1_115_STUDIO.exe
Next
Return to Graphisoft ArchiCAD
Tue May 21, 2024 12:11 am [ UTC ]
