NVIDIA 418.81 breaks Octane (FIXED 419.17 / 4.02/2018.1 RC2)
Forums: NVIDIA 418.81 breaks Octane (FIXED 419.17 / 4.02/2018.1 RC2)
Re: NVIDIA 418.81 breaks Octane (FIXED 419.17 / 4.02/2018.1 RC2)
Postby rodsteele » Fri Apr 12, 2019 6:06 pm
rodsteele Fri Apr 12, 2019 6:06 pm
bepeg4d wrote:Why not an option for you?
You need to ask to Nvidia about fixed Mac CUDA drivers, I guess.
ciao Beppe
Not an option for me because previous combinations of CUDA and Nvidia web drivers caused constant Kernel Panics and crashes to the login screen on my Mac. With the latest versions it's stable again so I won't downgrade.
Is there no there solution to be able to open my Octane files again, please?
rodsteele
Postby bepeg4d » Sat Apr 13, 2019 6:13 am
bepeg4d Sat Apr 13, 2019 6:13 am
every High Sierra users are using CUDA 410.130 driver with no issues, probably there is something different that is blocking your mac with High Sierra.
Have you tried to install a fresh version of High Sierra, maybe on an external hdd, with 410.130 CUDA drivers, and the GPU driver version that you are using now?
Please go to Apple menu, About this Mac, then press the System Report button, then go to menu File/Save, and share the resulting .spx file with me via PM, thanks.
ciao Beppe
Postby rodsteele » Sat Apr 13, 2019 7:57 am
rodsteele Sat Apr 13, 2019 7:57 am
bepeg4d wrote:Hi,
ciao Beppe
Thank you, much appreciated.
Since I had the GTX1080ti installed a year+ ago my Mac has had regular kernel panics. The company who installed it for me (Create Pro) could never figure out why it caused problems, so I just live with it. I only had it installed for GPU rendering. I have tried everything I could think of including new CPU trays, new RAM, new motherboard, fresh installs on different drives. But nothing has solved the KPs.
Recently I updated to the latest CUDA and Nvidia web drivers and it has been stable. Maybe coincidence? But I'm very reluctant to roll back the drivers.
I'll send the report you requested in a PM. Thanks again for replying.
Edit: I get "The requested users to be added do not exist." when I try to Pm you.
rodsteele
Postby bepeg4d » Mon Apr 15, 2019 2:59 pm
bepeg4d Mon Apr 15, 2019 2:59 pm
Please, roll back only the CUDA driver to 410.130.
418.xx versions of CUDA are not working with Octane.
About PM, my userid id is bepeg4d
ciao Beppe
Postby rodsteele » Tue Apr 16, 2019 4:39 pm
rodsteele Tue Apr 16, 2019 4:39 pm
bepeg4d wrote:Please, roll back only the CUDA driver to 410.130.
ciao Beppe
I tried rolling back this weekend and got a kernel panic. Any other suggestions about how I can render my Octane scenes please? Thanks.
rodsteele
Postby edwstoa » Tue Apr 16, 2019 5:20 pm
edwstoa Tue Apr 16, 2019 5:20 pm
Any update on this? It's been two months since this thread started.
edwstoa
Postby edwstoa » Tue Apr 16, 2019 5:29 pm
edwstoa Tue Apr 16, 2019 5:29 pm
Also, why did I just pay the last two months for a program that not only doesn't work, but also has wasted several days of my time trying to fix it?
edwstoa
Postby bepeg4d » Wed Apr 17, 2019 7:33 am
bepeg4d Wed Apr 17, 2019 7:33 am
@ edwstoa:
the issue with Nvidia drivers has been solved roughly after one week, so probably you are having other issues, or have a wrong installation.
Please write to [email protected] explaining your issue in detail, to have a direct support.
@ rodsteele:
please do the same, we need to better investigate what is going on with your mac.
ciao Beppe
Postby DERJUNG » Thu Apr 18, 2019 9:38 pm
DERJUNG Thu Apr 18, 2019 9:38 pm
So I work on the Mac, too. My computer is a Mac Pro 2010 with two gtx 1070. my system is high Sierra with the security update 2019-002 nr 2 :-). Cuda driver is the 410.130 and web driver 387.10.10.10.40.124. I can work with it. There are no kernel panics. I once had a Titan x in my Mac, maxwell generation. And I had stability problems with it. I think it was the problem with the power supply. A 250 Watt card with only 225watt to operate does not work well. And results in system crashes. PCIe slot gives 75 watts and the two Mini pci power cables each only 75 watts. So I built in the two 1070 which need 150 wat per card which fits exactly. Pcie slot + cable equal to 150. I don't know your configuration but if you don't supply the 1080ti with enough power you will have crashes.
MacPro 2x 3,46 Ghz / 64GB Ram / GTX 1070 + GTX 1070 macOS 10.13.6. CUDA 410.130. webdriver 387.10.10.10.40.124
RenderMachine 4x GTX 1080 WC / win10
DERJUNG
Postby rodsteele » Fri Apr 19, 2019 3:59 pm
rodsteele Fri Apr 19, 2019 3:59 pm
DERJUNG wrote:So I work on the Mac, too. My computer is a Mac Pro 2010 with two gtx 1070. my system is high Sierra with the security update 2019-002 nr 2 :-). Cuda driver is the 410.130 and web driver 387.10.10.10.40.124. I can work with it. There are no kernel panics. I once had a Titan x in my Mac, maxwell generation. And I had stability problems with it. I think it was the problem with the power supply. A 250 Watt card with only 225watt to operate does not work well. And results in system crashes. PCIe slot gives 75 watts and the two Mini pci power cables each only 75 watts. So I built in the two 1070 which need 150 wat per card which fits exactly. Pcie slot + cable equal to 150. I don't know your configuration but if you don't supply the 1080ti with enough power you will have crashes.
Thanks for this.
The card was installed by a third party company who also upgraded the CPUs and flashed the Mac from a 4,1 to 5,1.
How can I find out if the 1080ti is getting enough power, please? Before the 1080 was installed the Mac was completely stable, but since then the kernel panics have been regular. Really disruptive and annoying.
I have the card installed with a Powerlink adaptor.
rodsteele
PreviousNext
Return to Development Build Releases
Sun Jan 26, 2020 12:29 pm [ UTC ]
