NVIDIA 418.81 breaks Octane (FIXED 419.17 / 4.02/2018.1 RC2)
Forums: NVIDIA 418.81 breaks Octane (FIXED 419.17 / 4.02/2018.1 RC2)
Postby Goldorak » Tue Feb 05, 2019 10:02 pm
Goldorak Tue Feb 05, 2019 10:02 pm
NVIDIA 418.81 driver (Feb. 4th) doesn't work with Octane - please don't update yet! We are working with NVIDIA to fix ASAP. We need to recompile Octane 4/2018.1+ to work with this driver version, and will post an update to this thread once that is done and confirmed working. Thank you!
Update:
In order to resolve the OSL compilation issues experienced due to changes in the NVIDIA Drivers, you will need to ensure that you have installed a supported driver for your version of OctaneRender.
  • OctaneRender 4.02.1 and higher requires NVIDIA driver version 419.17 or higher.
  • OctaneRender 4.02 and lower requires NVIDIA driver version 417.71 or lower.
If you are using a driver that is not supported, you will either be unable to render at all, or renders will fail with OSL compilation errors noted in the OctaneRender Log.
Goldorak
Re: URGENT: NVIDIA 418.81 breaks Octane - don't update yet!
Postby msc4058 » Thu Feb 07, 2019 8:16 pm
msc4058 Thu Feb 07, 2019 8:16 pm
I followed all the instructions but Windows won't allow me to install 417.71. Any hope of getting this fixed soon? Losing a lot of time
msc4058
Postby LOVEXMEDIA » Thu Feb 07, 2019 8:29 pm
LOVEXMEDIA Thu Feb 07, 2019 8:29 pm
msc4058 wrote:I followed all the instructions but Windows won't allow me to install 417.71. Any hope of getting this fixed soon? Losing a lot of time
You went into safe mode and uninstalled 418.81 with DDU and after the restart it would not allow you to install 417.71?
LOVEXMEDIA
Postby msc4058 » Thu Feb 07, 2019 8:57 pm
msc4058 Thu Feb 07, 2019 8:57 pm
Yeah exactly.
msc4058
Postby msc4058 » Fri Feb 08, 2019 5:43 pm
msc4058 Fri Feb 08, 2019 5:43 pm
Hello,
Any update on getting this fixed? I am going on day 3 with no renders. Windows will not allow me to install 417.71 and I followed all the instructions. Don't want to do a complete reinstall of everything.
Matt
msc4058
Postby Seun116_1 » Fri Feb 08, 2019 6:22 pm
Seun116_1 Fri Feb 08, 2019 6:22 pm
msc4058 wrote:Hello,
Matt
I don't know how you've tried to, but i made the same mistake of updating to 418.81 and I just went to the Nvidia website and downloaded 417.71 and it worked for me.
https://www.nvidia.com/download/driverR ... 1906/en-us
Seun116_1
Postby paride4331 » Mon Feb 11, 2019 9:56 am
paride4331 Mon Feb 11, 2019 9:56 am
Matt
Hi Matt,
if you are running under Windows 10, you could disable automatic windows 10 update, then install 417.71 Nvidia drivers.
To get an effective Nvidia drivers installed, please use DDU Nvidia unistaller drivers, the best way to get a clean installation.
http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
paride4331
Postby msc4058 » Mon Feb 11, 2019 11:06 pm
msc4058 Mon Feb 11, 2019 11:06 pm
Thank you so much for your reply. Nothing is working.
1. Started in SafeMode
2. Ran DDU Nvidia Unistaller
3. Downloaded Nvidia 417.71 installer
4. Error on install (See photo)
Windows 10, version 1809
msc4058
Postby msc4058 » Mon Feb 11, 2019 11:07 pm
msc4058 Mon Feb 11, 2019 11:07 pm
Also turned off Auto update
msc4058
Postby paride4331 » Tue Feb 12, 2019 7:30 am
paride4331 Tue Feb 12, 2019 7:30 am
msc4058 wrote:Also turned off Auto update
Hi msc4058,
do you own a Nvidia Quadro series? model?
paride4331
Next
Return to Development Build Releases
Sat May 30, 2020 4:25 pm [ UTC ]
