Version 4.0-RC1.0 (obsolete experimental build) 15.08.2018
Forums: Version 4.0-RC1.0 (obsolete experimental build) 15.08.2018
Moderator: aoktar
Re: Version 4.0-RC1.0 (Latest experimental build) 15.08.2018
Postby noisyboyuk » Fri Aug 17, 2018 11:18 am
noisyboyuk Fri Aug 17, 2018 11:18 am
abstrax wrote:- In the C4D plugin, the scene update can hang sometimes. We fixed a few bugs in that area before RC1 got released, but haven't been able to reproduce this problem with RC1 anymore. If you still experience hangs during the scene update, please send us a scene plus instructions how to reproduce the hang.
Hey man! This is great news :)
I don't know if this helps but yesterday I made a post (on this page: viewtopic.php?f=85&t=68511&start=20 ) in which I reported update hanging in the IPR.
You'll see about three posts from me, the initial post is me trying to get my head around the issue and then there are two more further down where I managed to narrow it down a bit more.
In a nutshell, the way I managed to get it to crash is by using a particle system with a Sweep to make trails and after about 40 - 50 frames of animation Octane gets stuck updating. This doesn't happen in 3.08 (I tested it out) so I hope that helps.
I did attach a scene file (which will expire in 6 days) but it uses the Early Access build of X-Particles so I expect that might cause problems your end in identifying the issue. Just to be thorough, I spoke with Insydium and they couldn't identify an issue their end.
The initial post I made about this was the one marked "Thu Aug 16, 2018 1:11 pm" - I didn't want to make a mess of the thread by just re-posting stuff, I hope this was the right call :)
If you could let me know if this info is of any use that would be awesome, then I can just leave it to you guys and not bother anyone with it in future.
Cheers guys :)
noisyboyuk
Postby anklove » Fri Aug 17, 2018 1:52 pm
anklove Fri Aug 17, 2018 1:52 pm
Is it intended that Universal Sub material misses Medium input while simple Uni mat has it?
EDIT Also fake shadows in sub uber mat is super awaited!
i7 10700k | Win 10 64 bit | RTX 3090
anklove
Postby aoktar » Fri Aug 17, 2018 1:54 pm
aoktar Fri Aug 17, 2018 1:54 pm
anklove wrote:Is it intended that Universal Sub material misses Medium input while simple Uni mat has it?
No, missing input i believe
Postby khdownes » Fri Aug 17, 2018 2:15 pm
khdownes Fri Aug 17, 2018 2:15 pm
Hey Aoktar, can I possibly request a slight UI change with the emission channel?
A lot of the time when I mean to click on the texture input shader/button, I accidentally miss it and click the "blackbody emission" or "texture emission" buttons instead because they're so close.
This deletes the current shader and replaces it with a blank new one. Ctrl+Z doesn't work undo this, so the only option is rebuild the shader or close Cinema and go back to your last save.
Is it possible to to make this action undoable? Or just add some space between the texture shader button and the blackbody/texture emission buttons?
khdownes
Postby milo_dude » Fri Aug 17, 2018 5:20 pm
milo_dude Fri Aug 17, 2018 5:20 pm
The same version 1.0 in archive))
milo_dude
Postby aoktar » Fri Aug 17, 2018 8:00 pm
aoktar Fri Aug 17, 2018 8:00 pm
khdownes wrote:Hey Aoktar, can I possibly request a slight UI change with the emission channel?
I added UNDO for those. It will be available in V4-RC2-R1 build.
Postby helloimneil » Fri Aug 17, 2018 11:19 pm
helloimneil Fri Aug 17, 2018 11:19 pm
Could someone walk me through how I access the Denoiser Beauty pass that's been rendered from the Picture Viewer?
I can see the denoised beauty in the render layers within the picture viewer, but the saved file (an EXR), when opened in Photoshop, is black.
What am I missing?
helloimneil
Postby SRCOBB » Sat Aug 18, 2018 1:46 am
SRCOBB Sat Aug 18, 2018 1:46 am
Still just crashing when trying to open C4D...
what would help sort that out? Nvidia and Cuda drivers are up to date.
SRCOBB
Postby bepeg4d » Sat Aug 18, 2018 6:21 am
bepeg4d Sat Aug 18, 2018 6:21 am
Hi SRCOBB,
there is an issue in 4RC1 SDK with CPUs older than 2011, but has been already solved in 4RC2, so next version of plugin will not have this issue.
ciao Beppe
Postby aoktar » Sat Aug 18, 2018 9:25 am
aoktar Sat Aug 18, 2018 9:25 am
Here is newer build over latest SDK
viewtopic.php?f=85&t=68537
Previous
Return to Releases
Users browsing this forum: Google [Bot] and 4 guests
Wed May 15, 2024 2:32 pm [ UTC ]
