OctaneRender for AutoCAD Beta 1.20.1 [OBSOLETE]
Forums: OctaneRender for AutoCAD Beta 1.20.1 [OBSOLETE]
Autodesk AutoCAD (Integrated Plugin developed by OTOY, maintained by Paul Kinnane)
Postby face_off » Fri Nov 22, 2013 1:29 am
face_off Fri Nov 22, 2013 1:29 am
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for AutoCAD, build 1.20.1 (STABLE RELEASE). This version is compiled against Octane 1.20, so see the requirements for that build regarding compatibility with your video card.
The plugin requires AutoCAD 2013 or 2014, Windows 32bit or 64bit.
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- AutoCAD version and build number
- OctaneRender for AutoCAD version (ie. 1.20.1.10)
Change Log from release X.XXa
- N/A
For more information...
- Read the on-line manual
- Read the FAQ
- Post your question on this forum thread
Limitations
Refer to the on-line manual
Download Links
Download the plugin from the following links:
- Current version available from your Downloads page.
Support for AEC objects
Postby guillerodriguezv » Thu Feb 06, 2014 6:29 pm
guillerodriguezv Thu Feb 06, 2014 6:29 pm
Hi, it would very useful to make the autocad plugin support for AEC objects (MEP,Architecture Objects). It is not practical when you make a change to the original file and then converted to solids, you had to start all over again with the textures, please check this suggestion for the final release.
Laptop- Win 10 64- 32 Gig GTX 880m 8 Gig - Desktop Win 10 64- 16 Gig GTX 980 ti 8 Gig
guillerodriguezv
Re: OctaneRender for AutoCAD Beta 1.20.1 [TEST]
Postby face_off » Thu Feb 06, 2014 9:22 pm
face_off Thu Feb 06, 2014 9:22 pm
I agree - however there is no facility in the AutoCAD API to extract AEC object geometry. The only way to get vertices is to convert to solid - so unfortunately this is a necessary step.
If you want to not loose your textures, then use the Octane material "Save as Default" feature in the plugin for each of the AEC object material name - so when the plugin next encounters those material names, it will use the Octane setup you saved.
Re: OctaneRender for AutoCAD Beta 1.20.1 [STABLE]
Postby perro_abombao » Sat Feb 15, 2014 1:24 am
perro_abombao Sat Feb 15, 2014 1:24 am
Demo when?
perro_abombao
Postby face_off » Sun Feb 16, 2014 10:48 pm
face_off Sun Feb 16, 2014 10:48 pm
Demo when?
Hi - I will build a demo version against the latest Octane 1.31 engine later this week. I will post in this thread once it is available for download.
Postby face_off » Wed Feb 19, 2014 1:50 am
face_off Wed Feb 19, 2014 1:50 am
The demo version is now available - download from http://render.otoy.com/downloads.php.
Postby perro_abombao » Thu Feb 20, 2014 12:19 am
perro_abombao Thu Feb 20, 2014 12:19 am
face_off wrote:The demo version is now available - download from http://render.otoy.com/downloads.php.
Thanks!!!, sorry, I have a proplem.
perro_abombao
Postby face_off » Thu Feb 20, 2014 12:36 am
face_off Thu Feb 20, 2014 12:36 am
Ah, sorry. I will fix this and post back here when the download is ready.
Postby face_off » Thu Feb 20, 2014 4:43 am
face_off Thu Feb 20, 2014 4:43 am
The fixed demo version has now been posted at http://render.otoy.com/downloads.php.
Postby perro_abombao » Sat Feb 22, 2014 3:43 am
perro_abombao Sat Feb 22, 2014 3:43 am
thanks....!!!!
perro_abombao
Next
Return to Autodesk AutoCAD
Users browsing this forum: No registered users and 11 guests
Fri Apr 26, 2024 5:01 am [ UTC ]
