Actually it's fixed, but i'm checking a few more things.Yambo wrote:Thank you!aoktar wrote:It's about alpha processing with background image+render buffer. Will be fixed.Yambo wrote:Problem found.
When c4d background object is on, The image is not saved properly in picture viewer / saved blank.
Take a look at the images attached, one (Crappy) with background object on, and one standard.
(just saw that i didn't post the images mentioned, sorry for that)
Version 3.00 - R1.1 (25.05.2016)
With the same drivers and cuda update on the same scene, 2,25 version is almost impossible to Use on my iMac (GTX780M), while everything runs fast with 3,00 Beta2,0aoktar wrote:Previous version was always debug builds until now. With latest update we have two boost. One from plugin side and second is from Octane's geometry compiling. Guys from Otoy spend some effort to make the multi-processing better.Lambe wrote:Hi
I'm using Octane on a Mac Pro and an iMac 27. Both are going faster with 3,0
But especially the iMac became fluid now. Changing camera with the live viewer running was painful,
I had to wait a few seconds between each action. the change is impressive and this machine, which is not the fastest, is now usable comfortably.
I do not really know why...
but congratulations for this update.
But i think you have also some driver problems. We can't do nothing i suppose. Just try to keep "render priority=LOW and selected".
This to say that this Update is really great and to congrats the team.
Hello Aoktar,
I've tested v.3 b2 at different scenes. I know that the V3 core is different from the V2, but In V2 I can upload all my cards to 99% via priority and in V3 cloudn't.
Its float from scene to scence in about 79% to 94%. Does it architecture specificity or am I doing something wrong?
had a crash while rendering with Octane (beta2), since then, no way to relaunch c4d...
Only solution was to delete octane from the plugin menu...
Can you give me a better information as always expected?Huv wrote:Hi,
Hello,Proxell wrote:Hello Aoktar,
V3 is working different than V2. Having more clever on balancing the cores on works as i know. So that's not a matter to don't use all %100. Compare results for render times. It's significantly better performer on most scenes.
Unfortunately i do not know what else to say, i have no crash reports.
Nothing except the fact that after crash, when re-launching, c4d is not passing the "Initializing plugin" window...
I have to kill the app to be able to do something.
I''ve tried re-installing the plugin, but no way. If i do not delete the "octane" folder in the plugin folder, c4d does not restart...
Did you try this:
try to delete this file to reset your session:
Windows:
%APPDATA%/OctaneRender/otoy_credentials
Linux:
~/.OctaneRender/otoy_credentials
OSX: (you may have to use Finder's Go->Go To Folder... and type "~/Library/OctaneRender" - without the quotes - to get to that folder)
~/Library/OctaneRender/otoy_credentials
C4D 2025 | Win10
Yes, you are right Chriz, thats what I meant. Thanks.
Every Objekt wich I put under the new 1-Volume Generator will be moved with its Axis to one side and couldn't be moved nor resized.
Btw., did you check the old setups?
Thanks as well!
Thanks as well!
aoktar wrote:you're welcome. I have changed volume object for having two different behavior. 1-Volume generator 2-Vdb loader. I think old setups are corrupted due this. I'll check it.dinf wrote:Hey Ahmet,
About the new volume object: one simply drags any object below the volume, is that right?
If so, is there a way right now to center or position this object in the "domain"?
Mine will always move to an edge.
Vdb sequences are very big for quality outputs. So i haven't consider to upload it. Someone can re-simulate via houdini scene file.
I couldn't get the last question. Any images?
Chriz wrote:Hi aoktar,
i guess this is wthat he meant. I got the same behavior here. I know, disabeling the sphere will make it invisible. But the Fog seems to be centered at the edge of the FogVolume
| Win 10 | 64 GB RAM | AMD 5900X | RTX 3080 12 GB| C4D 21| C4Doctane v2022.1.1|
Ок, I see.aoktar wrote:Hello,Proxell wrote:Hello Aoktar,
