Cinema4D version 2022.1-XB4-(R2) (Experimental) 18.10.22
Forums: Cinema4D version 2022.1-XB4-(R2) (Experimental) 18.10.22
Moderator: aoktar
Re: Cinema4D version 2022.1-XB4-(R2) (Experimental) 18.10.22
Postby bepeg4d » Thu Oct 27, 2022 6:22 am
bepeg4d Thu Oct 27, 2022 6:22 am
kaisdaddy wrote:This latest experimental build (at least on the Mac version) does not contain an c4dOctane-R27.xlib file - only the R26 and R25 ones. It will not run on my M1 Ultra Mac Studio at all. I have not changed to Ventura and the previous build works fine, so that's not the issue.
- H
The link is wrong, please download the following one:
https://render.otoy.com/plugindownloads ... R4_OSX.zip
ciao,
Beppe
Postby aoktar » Thu Oct 27, 2022 11:34 am
aoktar Thu Oct 27, 2022 11:34 am
SSmolak wrote:
aoktar wrote:Probably you're not right. It's still way faster, checked because of your claim.
Right. Scatter is way much faster than Cloner ( especially with Push effector ). Cloner needs near 10 seconds to preprocessing while Scatter do it within 1-2 seconds. This is true using Octane LiveViewer. But in normal rendering preprocessing time is near the same for Scatter and Cloner.
Main purpose of scatter object that to offer much faster work on clones. You are using LV much more during works.
Also It's not possible! Probably comparing it wrong or missing something. There are different parts like prepare data/transfer it and calculate the render. You have to check all these seperately. Also share your example if you can't do that. Let's see
Postby SSmolak » Thu Oct 27, 2022 11:53 am
SSmolak Thu Oct 27, 2022 11:53 am
aoktar wrote:Also share your example if you can't do that. Let's see
Ok this is not important. You did great job that Scatter update within max 2 seconds even using "keep away" feature while Cloner needs 10 seconds. Sorry to bother you. Rendering preprocessing time is not as important.
SSmolak
Postby tripledistilled » Thu Oct 27, 2022 2:22 pm
tripledistilled Thu Oct 27, 2022 2:22 pm
bepeg4d wrote:Yes sorry, my fault, but OctaneX for Ventura is not ready yet... I'll keep you posted.
ciao,
Beppe
Many thanks. Looking forward to it.
tripledistilled
Previous
Return to Releases
Mon Jun 03, 2024 7:43 pm [ UTC ]
