Slow compilation in scenes with high object count.
Forums: Slow compilation in scenes with high object count.
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby matthewcastiglia » Thu Aug 09, 2018 9:39 pm
matthewcastiglia Thu Aug 09, 2018 9:39 pm
Hi everyone,
I see that there are a bunch of people having issues with slow compilation times in 3DS Max. I mentioned this in the facebook group and Jules believes "it’s definitely an object gathering overhead issue" within the 3DS Max plugin.
I noticed the slow compilation times when I was working on my arch viz projects. I decided to do a simple test using 10,000 arrayed cubes with a simple grey diffuse material.
Here are the compilation times
10,000 individual objects
3.08 - 8 minutes 2 seconds
V4 - 6 minutes 23 seconds
Same polycount - cubes joined into a single mesh.
3.08 - 1.23 seconds
V4 - 1.13 seconds
Attached is a screen grab of the scene
Win 10 64 | Geforce GTX 970 SLI | i7-5930K | 32GB
http://matthewcastiglia.com
matthewcastiglia
Re: Slow compilation in scenes with high object count.
Postby haze » Fri Aug 10, 2018 12:59 am
haze Fri Aug 10, 2018 12:59 am
Would you be able to share with us a max file and/or orbx please?
haze
Postby haze » Fri Aug 10, 2018 2:37 am
haze Fri Aug 10, 2018 2:37 am
haze wrote:Would you be able to share with us a max file and/or orbx please?
Likely this issue is resolved with this post:
viewtopic.php?p=343528#p343528
haze
Postby matthewcastiglia » Fri Aug 10, 2018 3:27 am
matthewcastiglia Fri Aug 10, 2018 3:27 am
Yes this is most likely the fix Jules posted on Facebook
https://www.facebook.com/577284846/post ... 153350862/
Jules Urbach:
"So we did our own testing today to get to the bottom of this - and this doesn't seem to be anything in the core engine, as you can load in thousands of objects and millions of polys per second in V4 standalone as expected. We will have to look into why the 3DS Max plug-in is causing the slowdown in gathering objects, but by all accounts this is a fixable bug, not anything having to do with Octane's ability to process scenes or geometry.
..and the 3DS Max bug is found and fixed, and scene compilation should be back to milliseconds, not minutes. Christophe will make a post on this update in the forums shortly. Thank you everyone who reported this to me, sorry this wasn't addressed much sooner."
matthewcastiglia
Return to Bug Reports
Wed Apr 21, 2021 9:04 pm [ UTC ]
