protovu wrote:Hi Sighman,
I may have messed up our control group.
Re-addressing:
the new attached file uses object layers, and they work like a charm, in 2.17. With the previously uploaded file, I may have
misled, as I did not want both objects to render simultaneously in the same space, but simply to toggle.
So, back to the original issue: models not showing up in 2.25, with or without object layers is the real problem. This is a major problem, shutting me out of 2.25.
Thank you for your help,
Rick
Can you specify in which frame the model is being dropped? I ran through all the frames without any issues.
Edit: actually, I did just reproduce it. Under investigation now...
