Update UV Transfrom from script?
Forums: Update UV Transfrom from script?
Postby bmustata » Fri Mar 16, 2018 8:25 am
bmustata Fri Mar 16, 2018 8:25 am
How can I update UV Transfrom (NT_TRANSFORM_VALUE) from code?
bmustata
Re: Update UV Transfrom from script?
Postby mojave » Sun Mar 18, 2018 11:48 pm
mojave Sun Mar 18, 2018 11:48 pm
Hi bmustata,
There are several nodes types that make use of NT_TRANSFORM_VALUEso you'll need to find the actual pin within that node using the Lua API browser.
In either case, once you find the right pin to read or write, these are the attributes you can access to:
I hope that helps.
mojave
Postby bmustata » Mon Mar 19, 2018 11:28 am
bmustata Mon Mar 19, 2018 11:28 am
Currently I'm trying something like this but it's not working right.
node:setPinValue(octane.P_TRANSFORM, octane.matrix.make3dTransformation({0,0,rotate}, {repeatX,repeatY,0}, {0,0,0}, 2))
bmustata
Postby bmustata » Tue Mar 27, 2018 8:16 pm
bmustata Tue Mar 27, 2018 8:16 pm
Any more help on how to update the rotateZ and scaleX & Y for a texture (NT_TEXT_IMAGE)?
bmustata
Postby mojave » Fri Apr 06, 2018 3:20 am
mojave Fri Apr 06, 2018 3:20 am
Nodes of the type NT_TEXT_IMAGE have a pin P_TRANSFORM of NT_TRANSFORM_VALUE type.
You need to set the attributes I showed you in my previous post to their individual values.
mojave
Return to Lua Scripting
Wed Aug 12, 2020 7:19 am [ UTC ]
