Finding all render targets
Forum for OctaneRender Lua scripting examples, discussion and support.
grimm
I can't get this to work right, doing something wrong for sure. :)
local renderTargets = octane.nodegraph.getRootGraph():findNodes(octane.NT_RENDERTARGET)
I would like to get a table back that holds all of the render target nodes in the root graph. Thanks,
roeland
Your line of code is correct, it should work.
This is how you collect all node names into a new array, and then print all elements of the array. This array can be used for the items property of a combo box.
-- the hash operator gives the length of the array (which is actually a table with integer keys)
print(#renderTargets)
names = {}
-- ipairs() returns an iterator object, which returns the integer keys and associated values in the array.
for i, rt in ipairs(renderTargets)
do
    names[#names + 1] = rt:getProperties().name   -- In an array the keys start at 1
end
for i, n in ipairs(names)
do
    print(n)
end
Roeland
grimm
Ah, I see, thanks Roeland. :lol: I was using the ipairs backwards when i was building the table. :oops:
grimm
Just another question about the code you wrote:
Do you have to do names[#names + 1] or can you just do names ?
roeland
In this case you can just use names[i].
The background is as follows: an array is a lua table with integer keys, starting from 1. So a three element array looks like this:
t[1] = "a"
t[2] = "b"
t[3] = "c"
Now if you leave a gap like this, a lot of code will stop working:
[code]
t[1] = "a"
t[2] = "b"
-- key 3 is not defined.
t[4] = "d"
Things like #t and ipairs(t) may assume there are only 2 elements in the array. Using t[#t + 1] makes sure you always insert with the next available key.
Roeland
grimm
Cool, that makes sense. Thanks. I program in Ruby for my real job so I'm familiar with hashes which appear to be very similar to Lua tables. It's going to take some time to understand when I should be building an array table or a key/value pair table. What is used mostly for Octane's API?
roeland
Both forms are used. If we need a list then it will be a table with integer keys. For properties we use a table with string keys. In this case the API doc will reference one of the items you can find under "Properties", where you can find the meaning of all the keys used.
Roeland
grimm
I'm having another problem, this time with the combo box component. I can't set the default selected item in the drop down list. I'm trying to set it with this line of code:
renderTargetDropDown:updateProperties { items = RENDER_TARGETS, selectedItem = RENDER_TARGETS[1] }
RENDER_TARGETS is the array of item, and they do show up in the drop down. What do you set the selectedItem to in order to set it? In the API docs it does say that this property is writable so it should be possible to set it, is that right? Thanks,
stratified
Just for completeness, you can write this a little bit more explicit: table.insert(names, rt:getProperties().name). For more info see http://www.lua.org/manual/5.1/manual.ht ... ble.insert.
cheers,
Thomas
stratified
grimm wrote:I'm having another problem, this time with the combo box component. I can't set the default selected item in the drop down list. I'm trying to set it with this line of code:
Hi grimm,
You're code is fine. It's a bug in the API. We'll fix this in the next release.
cheers,
Thomas
Return to “Lua Scripting”
