Wireframe geometry (atom array)
Forums: Wireframe geometry (atom array)
Postby jobigoud » Wed Sep 15, 2021 1:34 pm
jobigoud Wed Sep 15, 2021 1:34 pm
Hi everyone,
This is a script to create a solid wireframe version of a mesh. The script goes through the polygons and replaces edges with hair primitives and vertices with spheres.
Usage
1. Add a Scripted graph node and load the script "wireframe.lua" into it.
2. Plug the geometry node you want to convert into the Geometry input.
3. Adjust the radius of the spheres and rods using the Vertex radius and Edge radius fields.
Feedback, bug reports and suggestions are highly appreciated.
Lua script:
wireframe.lua
(11.51 KiB) Downloaded 279 times
Demo ORBX:
wireframe-demo.orbx
(74.99 KiB) Downloaded 286 times
jobigoud
Re: Wireframe geometry (atom array)
Postby elsksa » Sun Sep 19, 2021 2:06 am
elsksa Sun Sep 19, 2021 2:06 am
Nice results. Thank you for sharing it publicly.
elsksa
Postby jobigoud » Tue Sep 21, 2021 9:54 am
jobigoud Tue Sep 21, 2021 9:54 am
I updated the script to make it work better in Octane 2020 and Octane X.
jobigoud
Postby manalokos » Wed Nov 10, 2021 2:33 pm
manalokos Wed Nov 10, 2021 2:33 pm
Hi, great script!
I would add some improvements:
-Active/inactive checkbox
-Script is rebuilding mesh even if there is a change in the material, (should evaluate only if geometry changes?)
Kind regards
Filipe
manalokos
Postby jobigoud » Thu Nov 11, 2021 10:35 am
jobigoud Thu Nov 11, 2021 10:35 am
manalokos wrote:-Script is rebuilding mesh even if there is a change in the material, (should evaluate only if geometry changes?)
Thanks. I can't really tell that only the material changed unfortunately. We get a callback that the source geometry node changed somehow, but there is no granularity on what changed about it.
jobigoud
Return to Lua Scripting
Tue Jun 04, 2024 4:00 am [ UTC ]
