failed to load session "ubuntu"
Forums: failed to load session "ubuntu"
Discussion forum for ORBX on OTOY's Amazon AMIs
Postby charliex » Sat Nov 09, 2013 7:44 am
charliex Sat Nov 09, 2013 7:44 am
If you get this error after doing apt-get update / upgrade. Its because the NVIDIA driver has a soft link to its own glx.so, and that has to be replaced.
so do one of the following.
Solution A:
Find out the current version installed, with
ls -l /usr/lib/xorg/modules/extensions/
You'll see something like :-
lrwxrwxrwx 1 root root 16 Nov 9 07:12 libglx.so -> libglx.so.331.20
-rwxr-xr-x 1 root root 9815912 Nov 9 07:12 libglx.so.331.20
So using 331.20 as the XXX.YY
su root
mv /usr/lib/xorg/modules/extensions/libglx.so /usr/lib/xorg/modules/extensions/libglx.so.orig
ln -s /usr/lib/xorg/modules/extensions/libglx.so.XXX.YY /usr/lib/xorg/modules/extensions/libglx.so
exit
Solution B:
Go to the NVIDIA drivers page http://www.nvidia.com/object/unix.html and download the run script (using the SSH session, since graphics mode isn't working)
The way i did that was to go to the agree screen, and copy the link, then wget it in the SSH. I have tested this version
http://www.nvidia.com/content/DriverDownload-March2009/confirmation.php?url=/XFree86/Linux-x86_64/331.20/NVIDIA-Linux-x86_64-331.20.run&lang=us&type=GeForce
Important : Do not choose the option to configure the xorg.conf, if you do accidentally do that step, it will make a backup called xorg.conf.nvidia-xconfig-original , copy that to xorg.conf
Once you have downloaded the script to the OTOY Linux instance.
Stop the X Server too, add the 32 bit compatibility libraries.
sudo -s
service gdm stop
sh ./Linux-x86_64/331.20/NVIDIA-Linux-x86_64-331.20.run
exit
charliex
Return to ORBX on Amazon AMIs
Sun Jan 19, 2020 9:54 pm [ UTC ]
