Error exporting OCS from Revit 2022 plugin
Forums: Error exporting OCS from Revit 2022 plugin
Autodesk Revit (Integrated Plugin developed by Paul Kinnane)
Postby azims » Sat Apr 02, 2022 9:20 pm
azims Sat Apr 02, 2022 9:20 pm
Hi Faceoff,
I am using Revit 2022 to export an OCS to standalone. Every time I try to I get an error message (see attachment). The only way I can make this error go away is by clearing the Revit Cache folder. But after every export I need to clear the cache or I get the error again. Please provide a fix.
azims
Re: Error exporting OCS from Revit 2022 plugin
Postby face_off » Sun Apr 03, 2022 10:11 pm
face_off Sun Apr 03, 2022 10:11 pm
Hi
I couldn't reproduce this error. Are you on the English version of Revit? Does it happen with all scenes, or just one? What is the exact sequence of steps you are taking to export to OCS please?
Postby azims » Sun Apr 03, 2022 11:56 pm
azims Sun Apr 03, 2022 11:56 pm
Hi Faceoff,
Yes, I am using Revit 2022.1.2 (English version).
I open a perspective view in any revit file. Then for the 'first time' in that file I go to the Add-Ins tab and I click the Octane icon and this will launch the octane dialog box. Once in the dialog box, I can open the viewport and export Ocs from standalone.
Once I close the octane dialog box, if I click on the Octane icon on the Add-Ins tab to launch Octane again then I get the error message.
To avoid the error, sometimes restarting revit works otherwise like I mentioned before, I need to close revit, go clear the cache folder and come back to launch the Octane dialog box.
azims
Postby face_off » Mon Apr 04, 2022 11:21 am
face_off Mon Apr 04, 2022 11:21 am
Thanks.
I can now replicated this issue, and will post a new release to fix the problem in the next 24hrs.
Postby face_off » Tue Apr 05, 2022 5:37 am
face_off Tue Apr 05, 2022 5:37 am
Please see the latest version of the plugin at viewtopic.php?f=61&t=78762&p=411048#p411048 for a solution to this issue.
Postby azims » Sat Apr 09, 2022 5:05 pm
azims Sat Apr 09, 2022 5:05 pm
azims
Return to Autodesk Revit
Mon Jun 03, 2024 11:42 pm [ UTC ]
