large reolution viewport issues
Forums: large reolution viewport issues
Autodesk Revit (Integrated Plugin developed by Paul Kinnane)
Postby prehabitat » Mon Dec 02, 2013 8:21 pm
prehabitat Mon Dec 02, 2013 8:21 pm
Hi All,
I've started working with much larger res renders - basically so I can do some post-editing & add some photoshop entourage/styling without zooming on a pixelated image (I was previously working at 1920x1200 max res).
I'm now experiencing the difficulty of viewing the image through the viewport window & needing to pan around the viewport - this is a little annoying: is it possible to have a zoom function on the viewport so you can zoom in & out on the image as it resolves? (50% - 120% or so?)
Andrew
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
prehabitat
Re: large reolution viewport issues
Postby face_off » Mon Dec 02, 2013 8:39 pm
face_off Mon Dec 02, 2013 8:39 pm
Hi Andrew - have you tried locking the resolution? Then you can set the resolution in the "resolution" node and set the Viewport size to whatever you wish.
Postby prehabitat » Mon Dec 02, 2013 8:58 pm
prehabitat Mon Dec 02, 2013 8:58 pm
Thanks for the quick response Paul,
Please see image for what I'm trying to avoid: this is with viewport locked to my prefered output resoltion, and later resized...
When I unlock any changes to the viewport window directly affect the final image resolution in settings. (I know you know this - just stating what happens at my end for troubleshooting purposes)
p.s. I know viewing a scaled image is probibly not ideal in terms of spotting fireflies, or resolving anything detailed within the image, but it is alot more practical...
I'll try like this for a while and see how I go (I only started rendering res higher than screen resolution today)
thanks,
Andrew
prehabitat
Postby face_off » Mon Dec 02, 2013 9:11 pm
face_off Mon Dec 02, 2013 9:11 pm
I understand what you are after. There are some small viewport changes going through in the next version, and I can include a "scale" option with those.
Postby prehabitat » Wed Dec 04, 2013 7:44 am
prehabitat Wed Dec 04, 2013 7:44 am
I've seen the update with viewport scaling just now; thanks Paul!
Andrew
prehabitat
Return to Autodesk Revit
Wed Jun 05, 2024 10:08 am [ UTC ]
