Single GTX TITAN or Dual GTX 780Ti
glimpse
Tommes wrote:What happens if you want to render ultra hires images? Is it still working, only segmented, or isn't it working at all?
Tommes
if the resolution is so hign that You don't have enough vram, the render will fail & You'll not be able to do anything - so Vram does help if You need bigger resolutions.
aw1
thats very helpful info!
Can you please tell us what is the max resolution we can render with 780Ti with 3GB?
I am planning to render 4098x2160 resolution animation sequence, and my textures are approx. 1.7GB in that scene.
Windows 7 Pro, i7 4770, 16 GB Ram, 1TB SSD, Asus GTX780Ti 3GB
glimpse
aw1 wrote:thats very helpful info!
don't know for sure how to calculate & I can't look for numbers in program, 'cos at the moment rendering some tests.
For the record 8k Square seems to take 1.8GB of vRAM. So You should be just fine =)
fibernaut
I like to join this tech conversation. Currently i am rendering on a single GTX 780. The new 780ti with its 2880 cores is a bit faster. Does it make sense to buy another GTX 780 or can i take full advantage of the improved performance of a GTX 780ti in dual GPU mode?
Win 10 64 | 2x RTX 3080Ti 2x Xeon E5 2650v2 Supermicro X9DAi 128 GB
Win 10 64 | 1x RTX 4090 i9 9900K Gigabyte z390 128 GB
Win 10 64 | 2x RTX 3080Ti i7 2600 K 32 GB
glimpse
fibernaut wrote: can i take full advantage of the improved performance of a GTX 780ti in dual GPU mode?
You can take advamtage of all the power that is inside the card - I mean if it's faster You'll render faster - cards don't need to be the same. so in the end everything is 'bout the money You have to spend =)
voon
Makes me wonder, too ... what happens if your scene needs more than the 3 GB I have on my 780Ti? Does it warn? stop? crash? swap? slow down?
Return to “Lightwave 3D”
