Denoise pass color totally off
Forums: Denoise pass color totally off
Postby marchermitte » Wed Aug 17, 2022 1:51 pm
marchermitte Wed Aug 17, 2022 1:51 pm
Hello
I'm using multilayer exr to output all my passes. Just noticed that the denoise beauty pass color space is totally wrong compared with the beauty pass. It's way darker and over saturated with some blue dominant.
Using latest stable modo plugin version (OctaneRender_for_Modo15_2021_1_5_186)
Anyway to fix that BEFORE rendering?
And when It's too late, after rendering, does anyone found the proper settings to get the same image than the non denoised pass? Trying with hue/ saturation and exposure but it's not quite there yet...
(I'm dealing with animations so rendering everything out again is out of question now.)
Thank you
Marc Hermitte
Intel I7 4.5 Ghz, 24 gig ram, 2x Nvidia GTX 480, win 764bits
marchermitte
Re: Denoise pass color totally off
Postby elsksa » Wed Aug 17, 2022 6:08 pm
elsksa Wed Aug 17, 2022 6:08 pm
"Way darker and saturated" is often referring to a non-conformed scene-linear source.
Could you share both as a screenshot, if possible?
elsksa
Postby face_off » Wed Aug 17, 2022 11:04 pm
face_off Wed Aug 17, 2022 11:04 pm
Yes, a screenshot would help. It sounds like a color space or OCIO issue, so can you share those settings please?
Postby marchermitte » Thu Aug 18, 2022 12:00 am
marchermitte Thu Aug 18, 2022 12:00 am
https://imgur.com/a/Nph33NU
Tried the direct link to the image but the forum stopped the conection to the link so, here It is online.
Same rendering , same settings, only different passes, beauty and beauty denoised. I tried different gama (srgb, built in camera presets ) but still, same difference between the two renders.
Marc Hermitte
marchermitte
Postby marchermitte » Thu Aug 18, 2022 1:10 am
marchermitte Thu Aug 18, 2022 1:10 am
AND screen shots of the settings, tried both srgb and some of the built in presets... there is a definite shift in color and luminosity between the beauty and the denoised beauty.
Marc Hermitte
marchermitte
Postby face_off » Thu Aug 18, 2022 2:23 am
face_off Thu Aug 18, 2022 2:23 am
I could not reproduce the issue. Are you able to send me the scene please? Also, what are your Modo->Scene OCIO Config and Colorspace settings? What is you System->Preference->Rendering->OCIO and Color Space settings?
Postby face_off » Thu Aug 18, 2022 2:24 am
face_off Thu Aug 18, 2022 2:24 am
Also - if you export the scene to ORBX and render in Octane Standalone, do you see the same issue happening?
Postby elsksa » Thu Aug 18, 2022 11:57 am
elsksa Thu Aug 18, 2022 11:57 am
Curious to know the answers from Paul's questions.
• The "neutral" and "cyan-ish" screenshot are based on the same settings? I got confused by the settings screenshot.
• Does the issue occur without the denoiser?
• Is the export file format OpenEXR?
elsksa
Postby marchermitte » Thu Aug 18, 2022 11:51 pm
marchermitte Thu Aug 18, 2022 11:51 pm
I'm going to record a detailed video shortly, I have to fix, complete and send the anim asap.
But yes Esksa , all the settings are the same when I render as multilayer 16 bits exr, the beauty looks good and the denoied beauty looks totally off.
COuld It be the ioerx plugin I use in AfterEffects? I could send you one frame multilayer exr just for you to test ...
Marc Hermitte
marchermitte
Postby Hesekiel2517 » Sun Aug 21, 2022 1:52 pm
Hesekiel2517 Sun Aug 21, 2022 1:52 pm
is it possible that you rendered some frames and added or removed one AOV/Layer and rendered or rerendered the other frames? The Extractor plugin can not handle this scenario
Hesekiel2517
Return to Foundry Modo
Users browsing this forum: No registered users and 7 guests
Thu May 23, 2024 12:02 pm [ UTC ]
