OctaneRender™ Standalone 3.00 beta 3
abstrax
Hi all,
This is the 3rd beta release of v3 which fixes more bugs and is hopefully the last beta release before 3.00.
We split the v3 alpha/beta release notes into two posts: This one, which provides the download links and information specific to this particular release and a features post describing and discussing the new features and changes of 3.00. The features post will be continuously updated until we reach the stable version 3.00.
Alpha and beta version disclaimer
In contrast to v2 we want to do the alpha and beta testing publicly, to get more feedback earlier and to have changes tested more thoroughly. The plan is to let all users with a valid v2 license use the v3 alpha and beta versions. v3 alpha/beta versions will stop working on 1st June 2016.
Since there is a higher likelihood of severe bugs in alpha and beta versions you shouldn't use them for production work. It would be nice if you could test some production scenes with the alpha and beta versions, but you should definitely not rely on the stability of those versions to finish your projects.
In the Standalone you should be able to load v3 scenes in v2, losing only features provided in v3 and maybe some converted settings (like the new "mid level" in displacement nodes). With the plugins this isn't necessarily the case, which means that you should not create any plugin projects with v3 alpha/beta if you are not 100% sure that you want to upgrade to v3 or that you don't mind losing these projects when the beta period ends.
Offline authentication is disabled in alpha and beta versions.
CUDA requirements
Due to a CUDA compiler bug we had switch to CUDA 7.5, which means on Windows and Linux you may need to update your NVIDIA graphics driver to a current version which supports at least CUDA 7.5. On Mac OSX you may have to update the CUDA driver for Mac to a current version supporting at least CUDA 7.5.
Changes since 3.00 beta 2
  • Fixed crash when you enable an info pass while rendering PMC (see viewtopic.php?p=273892#p273892).
  • Fixed crash when using uniform subdivision.
  • Fixed kernel crash when a deep image file is saved.
  • Fixed incorrect mapping of 2nd or 3rd UV set on displacement triangles.
  • Prohibiting the multiple downloads of the same material from the LiveDB.
  • Fixed saving of the SSO license and credentials file in user folders with non-ASCII characters in the path.
  • Various other fixes in the SSO authentication.
  • On OSX use CMD instead of CTRL for hotkeys.
  • Shortcuts are now displayed in menus.
  • Made a first demo build for v3.
OctaneRender Standalone downloads
Windows
- 64-bit commercial version (installer)
- 64-bit commercial version (ZIP archive)
- 64-bit demo version (installer)
- 64-bit demo version (ZIP archive)
Mac OS X
- 64-bit commercial version (DMG image)
- 64-bit demo version (DMG image)
Linux
Photoshop workflow plugin download
You can download and install the updated plugin either via the Adobe Exchange platform (version 1.0.3 hasn't been made visible by Adobe yet) or you can download it from the link below and manually install it.
Windows and Mac OS X
- Photoshop extension (v1.0.3) (ZXP archive)
Happy rendering,
Your OTOY NZ Team
Rikk The Gaijin
Thank you!
matrix2012
1: Missing under Centos 7 Gnome the Buttons
Octane Render 3 linux missing the button.
2: OnlineLive status and Activity does not appear.
System: Centos 7.1 Gnome.
Sorry for my bad english
all the best
matrix2012
stratified
matrix2012 wrote:Hi,
all the best
matrix2012
Weird. Only in beta 3 or did this happen in alle subsequent releases as well?
matrix2012
all the best
matrix2012
I have tested again with Octane Render 2.25.
and the Octane Render 2.25 has the same problem.
calus
abstrax wrote: During subdivision surface calculation of subdivision level 1.
What does it mean ?
Is it about the "use adaptive subdivision" option ?
I can see the difference but not so much an improvement, still a mysterious feature. ;)
Also as soon as "adaptive subdivision" is enabled, the geometry doesn't respect anymore the "lenght unit" in import setting.
Pascal ANDRE
glimpse
Thank You!
Andrew88
thank you :)
please remember to fix the constant size of sphere primitives next time. i can finally import and render them but their size is constant, regardless how much i change the size of my particle shapes inside maya
have an nice day
gah5118
Thought it was maybe that beta 3 came out because this was happening with beta 2, however, it's also happening with beta3. we have 2 licenses and it is going strait to the error without asking for user info.
Message: "User validation error (ERR-5)."
Link: <none>
Timestamp: 1463678986
Code: 301
HTTP Status: 401
SSO Status: Signed In
Windows 8.1 | i7 950 | GTX 780ti | 24gb ddr3
gah5118
update, just ran alpha10 with success. now I can start back up beta 3.
another bug to report, is when you have a project open, then go to recent projects and open another, it crashes. instead, I have to select new project, then open a recent one so it wont crash.
