Hi there,
is it possible to solo a node? For example solo the bump image?
oblivion wrote:Hi there,
linograndiotoy wrote:oblivion wrote:Hi there,
Is that possible in the "standard" Blender?
Simply Ctrl+Shift+Click a node, and it is connected automatically to a viewer node (which is created if it doesn't exist).
linograndiotoy wrote:I seriously doubt we can have a "Viewer" node working with Octane.
ChrisH wrote:I usually do this manually, all the time, either connect a shader node directly to the output (and not via Mix shaders etc) or I have a loose Diffuse Material node that I connect a texture (or mix tex or w.e) to (the Diff input) and then to the shader output.
It really helps when your node tree gets more complex.
Users browsing this forum: No registered users and 5 guests
