when i try to use the plugin
Forums: when i try to use the plugin
Postby disturbed13 » Sat Jan 07, 2012 9:35 pm
disturbed13 Sat Jan 07, 2012 9:35 pm
it says that the octane render binary must be found
what on earth is this?
and any ideas on where i can find it or how to fix this issue?
disturbed13
Re: when i try to use the plugin
Postby TIG » Sun Jan 08, 2012 12:15 am
TIG Sun Jan 08, 2012 12:15 am
Have you read the Plugin's extensive instruction documentation ?
The Octane binary is the application-file [that's the Octane... '.exe' file on PC] that you run, and which makes Octane function.
How do you use Octane?
Is there a file-icon you double-click or activate it from a menu - that's the file to link to.
If you have a shortcut you double-click then get its properties [right-click] so you find the original exe file inside its folder - probably somewhere in the 'Program Files' tree...
In the Exporter dialog [first option] navigate to that exe file and set that as you binary application.
If you update the Octane application remember to update the Exporter's link, otherwise the older copy will be used, or even 'not found' if you've moved it.
TIG
TIG
Postby pixelrush » Sun Jan 08, 2012 12:18 am
pixelrush Sun Jan 08, 2012 12:18 am
I believe its asking you to set the path to the Octane.exe in the exporter UI.
Use the browse button to navigate to it.
I think this is described in the Help
HTH
Edit: see I was beaten to it. ;)
i7-3820 @4.3Ghz | 24gb | Win7pro-64
GTS 250 display + 2 x GTX 780 cuda| driver 331.65
Octane v1.55
pixelrush
Postby disturbed13 » Sun Jan 08, 2012 1:42 am
disturbed13 Sun Jan 08, 2012 1:42 am
yeah i figured it out
i had an idea and it worked
thanks for the reply guys
disturbed13
Return to SketchUp
Tue Jun 04, 2024 12:34 am [ UTC ]
