Moderator: aoktar
Postby SRCOBB » Fri Apr 02, 2021 11:11 pm
SRCOBB Fri Apr 02, 2021 11:11 pm
Hmm. I am using PR8. Still seeing those issues.
SRCOBB
Postby Robinbenito » Sat Apr 03, 2021 10:13 am
Robinbenito Sat Apr 03, 2021 10:13 am
Me too. I came here specifically because of the denoiser-issue. Can you give us an estimate for when this will be fixed? I need to know for a project if it's worth waiting..
Robinbenito
Postby Pixege » Sun Apr 04, 2021 6:08 am
Pixege Sun Apr 04, 2021 6:08 am
Otoy, I know it takes time to prepare a new PR10 for C4D and we should be patient, but I don't understand why you didn't release the PR9 which corrects at least the bug of watermarking Render. So many hours, so much electricity is wasted. Renders run overnight break after 35 frames. I don’t get it :/
MacBook Pro 16" | AMD Radeon Pro 5500M 8 GB | 2,3 GHz Intel Core i9 | 64 GB RAM + eGPU Razer Core X | Asus ROG Strix RX 5700 XT OC
Pixege
Postby LUKEBB » Mon Apr 05, 2021 1:46 am
LUKEBB Mon Apr 05, 2021 1:46 am
RENDER ISSUES -
Getting constant render issues. The render will start fine then around 10- 20 frames in will start rendering the same frame over and over. Sometimes it stops. It's been the same through PR5 / PR7 and now PR8. I have a iMac running Radeon Pro 580 and a Radeon Vii in a Razor eGPU. macOS BigSur 11.2. Please and thankyou for any help here - Takes me a week to render anything out :shock:
LUKEBB
Postby LUKEBB » Mon Apr 05, 2021 5:40 am
LUKEBB Mon Apr 05, 2021 5:40 am
this is what comes up when the render fails....
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
Check geometry subdivisons.
Picture viewer uses 'Render' subdivisions. But Live Viewer uses 'Editor' subdivision values.
Try to decrease 'render/editor' subdivison values.
Process Octane Passes -> en:1 ext:.png bits:9 saveML:0
Create imageState:0x00007FFC984900C0
StoreAllRenderPasses:0x00007FFC984900C0 passCnt:0
Tonemapping the all passes tm:0.004
Alloc multiBmp:0x00007FFB9BA40FC0
stored passes in:0 cores=1
pass [Reflection] not found...
pass [Shadow] not found...
pass [Ambient occlusion] not found...
Displaying passes in tm=0.427
freeRenderImages:0x00007FFC984900C0 multiBmp:0x00007FFB9BA40FC0
Passes saved in:0sec.
Delete imageState:0x00007FFC984900C0
Break rendering...
Create imageState:0x00007FFCB8B21EC0
StoreAllRenderPasses:0x00007FFCB8B21EC0 passCnt:0
OCT:could not request a tonemap because we don't have any renderthreads available.
Failed to tonemap the render passes!
Displaying passes in tm=0.432
freeRenderImages:0x00007FFCB8B21EC0 multiBmp:0x0000000000000000
**** RENDER FINISHED **** stat=3
LUKEBB
Postby Pixege » Wed Apr 07, 2021 7:33 am
Pixege Wed Apr 07, 2021 7:33 am
It's not okay to ignore the problem :(
Pixege
Postby NicolaMel » Wed Apr 07, 2021 3:42 pm
NicolaMel Wed Apr 07, 2021 3:42 pm
Hello, I'm a paying subscriber, I made a post on this forum almost a month ago, it wasn't even published. What do I have to do to get some help with Octane x crashing?
I'm using Cinema4d R23 plugin.
PR7 works, but crashes mostly when using bump maps on specular materials, also when noise scales gets small
PR8 doesn't work, live viewer gives a red message saying "EXTERNAL RENDER", whenever I start the live render Cinema crashes.
I am using an iMac Pro
2,3 GHz 18-Core Intel Xeon W
128 GB 2666 MHz DDR4
Radeon Pro Vega 64X 16 GB
NicolaMel
Postby jhansen » Thu Apr 08, 2021 7:59 pm
jhansen Thu Apr 08, 2021 7:59 pm
Pixege wrote:It's not okay to ignore the problem :(
I agree, this is approaching disrespectful. The issue has been known for quite some time now and not a word. One thing is for sure, I can't render but I'm still paying. I'm starting to wonder for what?
iMac Retina 5K (2019)
3,6 GHz 8-Core Intel Core i9
64 GB 2400 MHz DDR4
Render GPUs: 2 x Radeon VII 16 GB (Razer Core X)
Viewport GPU: Radeon Pro Vega 48 8 GB
macOS Big Sur 10.2.3 | Cinema 4D R23.110 | Octane X PR8
jhansen
Postby baugestalt » Mon Apr 12, 2021 2:15 pm
baugestalt Mon Apr 12, 2021 2:15 pm
to counter the negative vibe here; I'm using two rx5700 xt right now together with c4d and I think it's quite usable.
denoising and upscaling really is not working right now, but apart from that I have not found any major bugs in my workflow.
I'm looking forward to the pr10 release for c4d.
baugestalt
Postby Ainionu » Tue Apr 13, 2021 8:59 am
Ainionu Tue Apr 13, 2021 8:59 am
Last week I got my hands on Radeon RX6800XT ... just to learn that my Razer Core X does not support AMD 6000 series GPU's yet. Allegedly they are working on a update on Razer, but only god knows will it be on included on MacOS 11.5 or later update. So, anybody who is using Razer GPU case and cannot wait to work one of the Big Navys... just sit back and relax... :)
Ainionu
PreviousNext
Return to Maxon Cinema 4D
Users browsing this forum: Bing [Bot] and 14 guests
Tue Jun 04, 2024 11:06 am [ UTC ]
