OSL raytype contribution
Forums: OSL raytype contribution
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
Postby calus » Fri May 10, 2019 8:49 am
calus Fri May 10, 2019 8:49 am
This is a super simple but very powerful Octane OSl texture shader,
kind of a "live compositing" node, allowing to precisely control the contribution of each ray type :
Plugged in the opacity of a material it allows to lower visibility or hide an object in reflection, refraction, AO ,shadow , diffuse or camera.
Or can be used for example, as "amount" attribute of a mix texture/ mix material node, or in emission texture, ect ...
raytype_contrib.zip
(410 Bytes) Downloaded 307 times
> The blue sphere is not visible in reflection and refraction
Raytype_Contrib.orbx
(278.38 KiB) Downloaded 222 times
shader raytype_contribution(
   float cam = 1 [[string label = "Camera", float min=0, float max=1]],
   float shad = 1 [[string label = "Shadow", float min=0, float max=1]],
   float AO = 1 [[string label = "Ambient occlusion", float min=0, float max=1]],
   float diff = 1 [[string label = "Diffuse", float min=0, float max=1]],
   float refl = 1 [[string label = "Reflection", float min=0, float max=1]],
   float refr = 1 [[string label = "Refraction", float min=0, float max=1]],
   output color c = 0
    c = cam*raytype("camera") + shad*raytype("shadow") + AO*raytype("AO")
    + diff*raytype("diffuse") + refl*raytype("reflection") + refr*raytype("refraction");
EDIT: sorry there was a last minute bug in the script, this is fixed thanks to Milanm.
The shader seems to works just fine now.
Pascal ANDRE
Maya 2019, Windows 7, 128 GB RAM
4x GTX 1070, driver 430.39
calus
Re: OSL raytype contribution
Postby frankmci » Sat May 11, 2019 7:49 pm
frankmci Sat May 11, 2019 7:49 pm
As much as I love Milan's RayType scripts, I've had very little success getting the animators I support to use them on their own. I think this one will be more intuitive for them, and resolve a lot of complaints they have about rendering with an unbiased engine. It will also save a lot of time setting up multi-pass renders and fixing things in the composite.
Many thanks!
Technical Director - C4D, Maya, AE, - Washington DC
frankmci
Postby calus » Sat May 11, 2019 9:46 pm
calus Sat May 11, 2019 9:46 pm
frankmci wrote:As much as I love Milan's RayType scripts, I've had very little success getting the animators I support to use them on their own. I think this one will be more intuitive for them, and resolve a lot of complaints they have about rendering with an unbiased engine. It will also save a lot of time setting up multi-pass renders and fixing things in the composite.
Indeed both scripts are complementary, Milan' raytype.osl is a switch between ray types, while this one is a modulator for each ray type.
Pascal ANDRE
calus
Postby frankmci » Tue May 14, 2019 12:32 pm
frankmci Tue May 14, 2019 12:32 pm
calus wrote:Indeed both scripts are complementary, Milan' raytype.osl is a switch between ray types, while this one is a modulator for each ray type.
Yes, indeed. I don't mean to belittle Milan's wonderful contributions! I've already put them to good use many times. While it's certainly possible to get the same functionality with his great tool, often a simple on/off is what the doctor ordered, greatly simplifying the compositing phase.
While a big part of my job is helping solve other people's problems, they're not always thrilled with the solutions I offer. There's something to be said for simplicity, especially when trying to introduce new things to people already under deadline pressures. :)
Many thanks to all those who put in the time and effort, then go the extra mile to share their expertise with the community!
frankmci
Postby fantome » Wed Jun 05, 2019 11:11 pm
fantome Wed Jun 05, 2019 11:11 pm
Thanks for the great shader it is very useful for reflection pass.
I think i have encounter a bug with the refraction.
- take a bunch of sphere with specular shader
- put an environment
- activate reflection and refraction pass
- plug the osl node in opacity
When you set :
- reflection to 0 in osl node -> it works you get the exact same thing without object reflections
- refraction to 0 in osl node -> it doesn't work, in fact the environment position is not the same and it is inverted
fantome
Postby Antoncromas » Wed Jun 19, 2019 3:56 pm
Antoncromas Wed Jun 19, 2019 3:56 pm
This is fantastic, thank you!
Antoncromas
Postby HHbomb » Thu Jun 27, 2019 8:46 am
HHbomb Thu Jun 27, 2019 8:46 am
Otoy team should make this node as native... :!:
| win 10 64 | i7 5930K + 2 x GTX 20802ti | 3dsmax 2021 |
HHbomb
Postby Goldorak » Thu Jun 27, 2019 9:14 am
Goldorak Thu Jun 27, 2019 9:14 am
HHbomb wrote:Otoy team should make this node as native... :!:
Agreed
Goldorak
Postby HHbomb » Fri Jun 28, 2019 5:50 am
HHbomb Fri Jun 28, 2019 5:50 am
Cool !! Thanks :mrgreen:
HHbomb
Postby Iceman9 » Sat Jul 13, 2019 8:27 pm
Iceman9 Sat Jul 13, 2019 8:27 pm
I like the shadow catcher as it currently is. So please don't eliminate the existing option, just add alternatives.
Iceman9
Next
Return to Resources and Sharing
Wed Jan 27, 2021 2:03 am [ UTC ]
