Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
Postby bepeg4d » Wed Sep 16, 2020 8:35 am
bepeg4d Wed Sep 16, 2020 8:35 am
The issue with PR1 support has been solved now!
ciao Beppe
Postby jschoenith » Wed Sep 16, 2020 7:24 pm
jschoenith Wed Sep 16, 2020 7:24 pm
Thanks Beppe. Any update on when we can expect Octane X PR2 for C4D?
jschoenith
Postby aoktar » Wed Sep 16, 2020 9:26 pm
aoktar Wed Sep 16, 2020 9:26 pm
jschoenith wrote:Thanks Beppe. Any update on when we can expect Octane X PR2 for C4D?
This week if we're lucky!
Postby carlabrando » Wed Sep 16, 2020 9:34 pm
carlabrando Wed Sep 16, 2020 9:34 pm
Hi!I am building a computer purely and exclusively to be able to use Octane with C4D, but first I wanted to confirm if with these specifications I would have no problem.
* Intel I7-10700 4.8Ghz 16Mb S.1200
* Mother MSI (1200) B460M Bazooka
* Nvidia Geforce RTX 2060 Super Ultra Gaming 8Gb
* Ram PNY XLR8 GAMING 16GB 3200Mhz RGB
* Ssd Adata XPG Spectrix S40G RGB 256GB M.2 2280
* HDD 1TB Western Digital Sata III 64Mb 3.5" Blue
* Power supply 750W EVGA N1
* CPU Cooler Xigmatek WindPower WP964 RGB
* Thermaltake Versa H15 Black
Will it work??
thanks!!!!
carlabrando
Postby Stathis » Wed Sep 16, 2020 11:02 pm
Stathis Wed Sep 16, 2020 11:02 pm
in OctaneX, AI Denoiser is performed by the CPU, not the GPU, so it is a bit slower to calculate, but it does not affect GPU memory, and does not need to select a GPU for it.
Note that you need a CPU from 2015 or newer, to have the necessary instructions to perform AI denoiser.
Is this going to change in the future so we can use GPU for denoise or is this some hardware limitation for AMD gpus?
Stathis
Postby Goldorak » Thu Sep 17, 2020 12:09 am
Goldorak Thu Sep 17, 2020 12:09 am
it may change in the future, but we don’t have an exact ETA yet.
Goldorak
Postby ismo2020 » Thu Sep 17, 2020 7:20 am
ismo2020 Thu Sep 17, 2020 7:20 am
will XFX Thicc III AMD Radeon RX 5700 XT 8GB run octane X for cinema 4d on my MacBook pro ??
my specs
MacBook Pro (15-inch, 2019)
2.3 GHz 8-Core Intel Core i9
16 GB 2400 MHz DDR4
catalina OS
ismo2020
Postby Weezer » Thu Sep 17, 2020 7:33 am
Weezer Thu Sep 17, 2020 7:33 am
[quote="carlabrando"]Hi!I am building a computer purely and exclusively to be able to use Octane with C4D, but first I wanted to confirm if with these specifications I would have no problem.
If it runs C4D it should work – but I'd suggest building a PC with room and power for more than one GPU. Octane is powerful, but it still needs hardware to work; put two GPUs in and you'll really notice the difference. Alternatively, make sure your build can support the latest Ampere GPUs (30xx series), which are way more powerful. If you're speccing a PC now, I'd future proof it as much as possible.
Weezer
Postby Weezer » Fri Sep 18, 2020 9:29 am
Weezer Fri Sep 18, 2020 9:29 am
Are we feeling lucky?
[EDIT] I guess not...
[EDIT 2] How about this week?
Weezer
Postby atracksler » Mon Sep 21, 2020 3:01 pm
atracksler Mon Sep 21, 2020 3:01 pm
Hi guys,
Is there a way to lock the viewport to a camera? It nly seems to lock to a resolution. I could lock to a camera in RS, Cycles, and Arnold....
atracksler
PreviousNext
Return to Resources and Sharing
Tue Jun 04, 2024 2:18 pm [ UTC ]
