Hydra Solaris
Postby mitchino » Fri Dec 01, 2023 9:21 am
mitchino Fri Dec 01, 2023 9:21 am
Mega exciting Beppe! Once again though, does it work in the live viewer and make that faster?
And how does VRAM work? If I have 64GB on a mac and 24GB on a 3090 PC what happens?
mitchino
Postby bepeg4d » Mon Dec 04, 2023 8:08 am
bepeg4d Mon Dec 04, 2023 8:08 am
yes sure, it works in Live View too!
About VRAM, obviously you need to keep an eye on scene VRAM consumption, if it is greater than Render-Node VRAM, the Out-of-core option can be activated in Render Node, but render speed contribution goes down.
The mac M1/M2/M3 is the Workstation in Network Rendering, it prepares the scene, starts rendering with internal GPU, and sends the already prepared scene to Render-Nodes.
So the key is to have 10Gbit Ethernet connection/sSwitch or greater, between primary Workstation Mac, and Render-Node machines.
1Gbit Ethernet connection is the minimum, while WiFi connections are not good, there is too much latency.
Btw, there is a little delay in 2024.1 OctaneX version, but it should be ready for the end of this week.
viewtopic.php?f=33&t=82267&start=20#p429564
Stay tuned...
ciao,
Beppe
Postby cjadams » Mon Dec 04, 2023 1:54 pm
cjadams Mon Dec 04, 2023 1:54 pm
bepeg4d wrote:…Btw, there is a little delay in 2024.1 OctaneX version, but it should be ready for the end of this week.
Any word on when DCC’s plugins will be updated to this version too?
Stay tuned...
ciao,
Beppe
cjadams
Postby spybreak » Mon Dec 04, 2023 6:15 pm
spybreak Mon Dec 04, 2023 6:15 pm
Super excited to finally try out network rendering, thanks for giving us a preview of how it runs!
While the alpha is great I'm really looking forward to the C4D plugin once we're in beta phase. Its going to be such a huge help for my job.
bepeg4d wrote:Hi,
Stay tuned...
ciao,
Beppe
spybreak
Postby mitchino » Tue Dec 05, 2023 7:44 am
mitchino Tue Dec 05, 2023 7:44 am
Thanks Beppe, along with future optimisation for hardware raytracing on the M3, this is going to be a total game changer for mac users.
mitchino
Postby bepeg4d » Fri Dec 08, 2023 3:58 pm
bepeg4d Fri Dec 08, 2023 3:58 pm
about the spinning beachball issue after closing Live View, I was finally able to reproduce it!
It happens when RedShift plugin is activated in C4D.
RedShift is now included in C4D from R26, but you need a license to activate it.
We didn't have a license before, so RedShift was installed but not activated, and the issue was impossible to be reproduced.
The devs are looking at it (not an easy fix), but it seems that I have found a workaround.
First of all, please close c4d, then delete the oct.dat file at the following path, the c4doctane preferences will be reset to default, and a new oct.dat file will be created on next c4d start:
/Users/USERNAME/Library/Preferences/Maxon/Maxon Cinema 4D R2X_RANDOM_CODE/prefs/oct.dat
Then you need to load the following Octane.l4d layout at startup, or just after starting, then load the Standard c4d layout, and you should be able to open Live View and close it without the spinning beachball issue.
Octane.l4d.zip
(31.59 KiB) Downloaded 936 times
ciao,
Beppe
Postby SimonKn » Mon Dec 11, 2023 3:58 pm
SimonKn Mon Dec 11, 2023 3:58 pm
bepeg4d wrote:Hi,
Stay tuned...
ciao,
Beppe
Any update on this Beppe? Would be really cool to start Networking things here
SimonKn
Postby Dean » Wed Dec 13, 2023 7:18 pm
Dean Wed Dec 13, 2023 7:18 pm
Does Octane for Apple Silicon work properly on the new macOS Sonoma 14.2? I'm afraid to install since the system update grounded my work for 3 weeks. Let us know.
Dean
Postby bepeg4d » Thu Dec 14, 2023 8:26 am
bepeg4d Thu Dec 14, 2023 8:26 am
no problems here with macOS Sonoma 14.2.
For c4doctane users, new 2023.1.1 is out with a fix for Live View spinning beachball issue, and other fixes:
https://render.otoy.com/plugindownloads ... .1_OSX.zip
ciao,
Beppe
Postby bepeg4d » Fri Dec 22, 2023 8:14 am
bepeg4d Fri Dec 22, 2023 8:14 am
New Standalone 2024.1-Alpha2 also for macOS Apple Silicon M1/M2/M3 with multi platform Network Rendering support:
viewtopic.php?f=33&t=82826#p430157
Merry Christmas :D
ciao,
Beppe
PreviousNext
Return to Hydra Solaris
Wed Jun 05, 2024 7:24 pm [ UTC ]
