[Script] [MEL] [Maya plug 2.X] Switch textures & Add Shader
Forums: [Script] [MEL] [Maya plug 2.X] Switch textures & Add Shader
Sub forum for help and tutorials.
Postby blackshore » Sun Jun 04, 2017 3:42 pm
blackshore Sun Jun 04, 2017 3:42 pm
Hello folks,
I thought I would share two scripts that could come in handy.
Good luck with your projects! =D
Creates shaders of your choice to selected objects:
Suggested usage:
When working with new scene from scratch or export to Substance.
// Creates Shaders to selected objects
// Select objects in scene and run
// Michael Blackshore 2015 (C)
// Usage is without any restrictions
string $selectedObjs[] = `ls -sl`; //get selected objects
for ($obj in $selectedObjs){ //iterate on selected objects
   string $newMat = `shadingNode -asShader "octaneDiffuseMaterial"`; // creates a diffuse. Switchable to the materials below:
   // octaneMixMaterial= Mix material
   // octaneSpecularMaterial= Specular
   // octaneGlossyMaterial = Glossy
   // octanePortalMaterial = Portal
   string $rnMat = `rename $newMat ($obj + "_Diffuse_Mat")`; //renames to Mesh name + Diffuse_MAT [not needed]
   string $newSG = `sets -renderable true -noSurfaceShader true -empty -name ($rnMat + "SG")`; //create a shading group
   connectAttr -f ($rnMat + ".outColor") ($newSG + ".surfaceShader"); //connect shading group to lambert
   sets -e -forceElement $newSG $obj; //connect material to object
Replace textures in existing shader three.
Suggested usage:
Comes in handy when does multiple objects of the same type, examples, books in bookshelfs, plates etc.
// Replaces textures in existing shader three.
// Select octane Image textures in Hypergraph and run.
// Row 13 contains source and target. It will search for First input and replace it with the second.
string $octaneTextures[] = `ls -sl`;
for ($i=0; $i< (`size $octaneTextures`); $i++){
    if (`attributeExists "File" $octaneTextures[$i]`){
        string $texture = `getAttr ($octaneTextures[$i] + ".File")`;
        //replace old path with new path
        string $result = substituteAllString($texture, "R_A", "L_A"); // Edit The two inputs to your need.
        //sets attribute in node
        setAttr -type "string" ($octaneTextures[$i] + ".File") $result;
        print ($result + "\n");
blackshore
Return to Help / Tutorials
Who is online
Fri May 10, 2024 12:01 pm [ UTC ]
