Local DB .ORBX import error
Forums: Local DB .ORBX import error
Sub forum for bug reports
Moderator: JimStar
C. RAM Capacity (i.e. 6 GB)
Postby itsallgoode9 » Thu Apr 30, 2020 10:17 pm
itsallgoode9 Thu Apr 30, 2020 10:17 pm
I created an .ORBX material in maya 2019 (in the 2019 plugin) and I get the following error:
connectAttr -f Medium_Basalt.outColor Medium_BasaltSG.surfaceShader;
// Connected Medium_Basalt.outColor to Medium_BasaltSG.surfaceShader. //
// Error: Octane LiveDB: error creating Octane-DB node //
// Error: file: C:/Program Files/Autodesk/Maya2020/scripts/others/propertyPanel.mel line 829: No object matches name: Vertex_displacement_mixer //
I attempted this on a brand new, empty, scene as well as my scene originally created in 2019
It works fine to manually import that material via .ORBX material node but not via LocalDB.
Intel i7-3930K, 64gb RAM, Asus X79 Deluxe mobo, 2x EVGA 780 6gb (for rendering), 1x PNY quaddro k4000 (for display)
Windows 8.1 x64, Maya 2014, Octane Render v2
itsallgoode9
Re: Local DB .ORBX import error
Postby JimStar » Mon May 11, 2020 11:18 pm
JimStar Mon May 11, 2020 11:18 pm
Will be fixed in the next version.
JimStar
Postby itsallgoode9 » Sat May 30, 2020 5:04 am
itsallgoode9 Sat May 30, 2020 5:04 am
thank you jimstar
itsallgoode9
Postby packetslave » Wed Dec 09, 2020 4:17 pm
packetslave Wed Dec 09, 2020 4:17 pm
Should this be fixed in the current release? I have several ORBX files in my local DB with materials that work fine in Octane/Standalone and Octane/C4D, but refuse to import (with the same "error creating Octane-DB node" message in Maya.
Windows 10
Maya 2020.3
OctaneRender_VR_for_Maya_2020.1.5_-_17.32
packetslave
Postby BK » Thu Jan 14, 2021 9:06 pm
BK Thu Jan 14, 2021 9:06 pm
packetslave wrote:Should this be fixed in the current release? I have several ORBX files in my local DB with materials that work fine in Octane/Standalone and Octane/C4D, but refuse to import (with the same "error creating Octane-DB node" message in Maya.
Windows 10
Maya 2020.3
hello Packetslave,
Thank you so much!!
The LocalDB should work in Maya too if it works fine in Octane Standalone.
Could you please PM me a sample of the local DB file for us to test?
Cheers
Kind Regards
bk3d
BK
Return to Bug Reports
Mon Jun 03, 2024 11:20 pm [ UTC ]
