segmentation fault crash during render
Forums: segmentation fault crash during render
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby arokhsar » Sun Feb 28, 2021 8:43 pm
arokhsar Sun Feb 28, 2021 8:43 pm
I am getting crashes at different frames during rendering, but no crashes playing my project through the IPR. Below is my system information, crash log, and some things I have tried to fix it:
- turning off async save
- not rendering to mplayer
- using file cache on all nodes
- recreating the ROP node
If this is not enough, I can wrap up the project file and send it. The crash log is identical each time. Thanks in advance!
Windows 10 Pro 1909
GeForce RTX 3090 FE 24GB
RAM 32GB
Nvidia game ready 461.40
OctaneRender plugin 2020.2.0.4
Houdini FX Version 18.5.408
Crash report from arokh; Houdini FX Version 18.5.408 [windows-x86_64-cl19.16]
Uptime 863 seconds
Sun Feb 28 12:50:17 2021
Caught signal 11
Traceback from 5676 ThreadId=0x00000f48
CURRENT THREAD 3912
+0x7ff807e9df59 [Octane::ApiItem::pluginData] C:\Program Files\OTOY\Octane for Houdini\bin\octane.dll
+0x7ff810eb4bca [CMDextendLibrary] C:\Program Files\OTOY\Octane for Houdini\dso\HoudiniOctane_18.5.462_vr.dll
+0x7ff810ee31c7 [HoudiniCompilerVersion] C:\Program Files\OTOY\Octane for Houdini\dso\HoudiniOctane_18.5.462_vr.dll
+0x2588e294 [ROP_Node::nextExecute] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libROP.dll
+0x25889d4f [ROP_Node::execute] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libROP.dll
+0x25894d7b [ROP_RenderItem::render] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libROP.dll
+0x25899348 [ROP_RenderManager::renderOrder] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libROP.dll
+0x25898c5b [ROP_RenderManager::render] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libROP.dll
+0x25884be1 [ROP_Node::renderCommand] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libROP.dll
+0x258842a8 [ROP_Node::doRenderCommand] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libROP.dll
+0x25883c40 [ROP_Node::cmdRender] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libROP.dll
+0x26a3ec8a [CMD_Manager::runCommand] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libCMD.dll
+0x26a2b1e5 [CMD_Manager::internalExecute] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libCMD.dll
+0x26a3d4fa [CMD_Manager::processInput] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libCMD.dll
+0x26a3bf90 [CMD_Manager::internalSendInput] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libCMD.dll
+0x26a3f20d [CMD_Manager::sendInputNoLock] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libCMD.dll
+0x26a3a115 [CMD_Manager::executeNoLock] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libCMD.dll
+0x26a35825 [CMD_Loop::setupForStart] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libCMD.dll
+0x270f5561 [tbb::interface7::internal::task_arena_base::internal_execute] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\tbb.dll
+0x4d7a1175 [TBBPROXY_TaskArenaExecute] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libTBBPROXY.dll
+0x26a39fb5 [CMD_Manager::execute] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libCMD.dll
+0x10e0969d [OPUI_RenderDialog::launch] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libOPUI.dll
+0x25889970 [ROP_Node::doRenderCback] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libROP.dll
+0x123cea82 [OP_Node::triggerParmCallback] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libOP.dll
+0x1443270d [PSI2_DialogPRM::performParmCallback] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libPSI2.dll
+0x10cd00f5 [OPUI_DialogPRM2::performParmCallback] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libOPUI.dll
+0x1442b8e4 [PSI2_Dialog::triggerParmCallback] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libPSI2.dll
+0x14427db9 [PSI2_Dialog::parmChanged] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libPSI2.dll
+0x144579e3 [PSI2_Vector::changed] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libPSI2.dll
+0x112449ef [UI_Button::buttonTriggered] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libUI.dll
+0x11360784 [UI_TriggerButton::buttonTriggered] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libUI.dll
+0x11244b82 [UI_Button::endSelect] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libUI.dll
+0x10a802ce [SI_ParmButton::endSelect] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libSI.dll
+0x1137b96a [UI_Window::handleEvent] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libUI.dll
+0x11316654 [UI_Queue::processNextEvent] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libUI.dll
+0x113141f9 [UI_Queue::drain] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libUI.dll
+0x11314608 [UI_Queue::eventLoop] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libUI.dll
+0x10afb4d6 [AP_Interface::loadWindowGeometry] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libSI.dll
+0x10afbf0d [myWinMain] C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libSI.dll
+0x1400019ce C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\houdinifx.exe
+0x14000232a C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\houdinifx.exe
+0x7ff87eb97c24 [BaseThreadInitThunk] C:\WINDOWS\System32\KERNEL32.DLL
+0x7ff88060d721 [RtlUserThreadStart] C:\WINDOWS\SYSTEM32\ntdll.dll
arokhsar
Re: segmentation fault crash during render
Postby juanjgon » Mon Mar 01, 2021 8:45 pm
juanjgon Mon Mar 01, 2021 8:45 pm
Hmm, the log seems to come from H18.0.408, but the loaded plugin is HoudiniOctane_18.5.462_vr.dll. This is going to be a problem for sure. Please check your houdini.env or packages config file to be sure that both Houdini and the plugin versions match. Using the ${HOUDINI_VERSION} tag in the config files usually helps to avoid these problems.
juanjgon
Return to Bug Reports
Mon May 20, 2024 6:05 pm [ UTC ]
